DIY Speaker install on G35 sedan with non-bose
Old Sep 5, 2005 | 12:28 AM
rupdog326's Avatar
Out of many - one people
I have decided to start an upgrade on my 2004 sedan (without the bose system) using Polk DB series speakers. Just wanted to say thanks to khsonic03 for some good info https://g35driver.com/forums/audio-video-electronics/65333-audio-upgrade-complete-pics.html. I will skip the door removal because it has been documented several times and because it is fairly easy. I think there is some confusion between the Bose and the non bose system and maybe this install will clear things up.
This is the factory speaker that was removed from the front door.
Note that the speaker is integrated into the speaker mount. It is all one assembly. You cannot use this speaker mount to mount new speakers. You have to buy a spacer or make one yourself. I decided to make one myself using 3/4" MDF.
Check out this Do it yourself webpage.
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image058.jpg   DIY Speaker install on G35 sedan with non-bose-image056.jpg
Old Sep 5, 2005 | 12:39 AM
rupdog326's Avatar
The spacer was made by tracing the factory speaker onto either a template or unto the MDF directly. A jigsaw was then used to cut out the new spacer. This is the finished product.
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image052.jpg   DIY Speaker install on G35 sedan with non-bose-image053.jpg   DIY Speaker install on G35 sedan with non-bose-image061.jpg
Old Sep 5, 2005 | 12:44 AM
rupdog326's Avatar
The speakers used for the front doors are 6.5" Polk DB series components. I am very sorry for the low resolution photos. The factory speakers that were removed were panasonic as the picture below shows. In case you can't see the lettering, they are rated at 4 ohms and 40 watts.
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image059.jpg
Old Sep 5, 2005 | 01:05 AM
rupdog326's Avatar
This is the finished product ready to be installed tommorrow. Stay tuned.
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image060.jpg   DIY Speaker install on G35 sedan with non-bose-image063.jpg
Old Sep 5, 2005 | 11:54 PM
rupdog326's Avatar
This is what the stock tweeter looks like in its bracket.
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image066.jpg
Old Sep 5, 2005 | 11:56 PM
rupdog326's Avatar
This is the woofer part of the component system installed
Attached Thumbnails DIY Speaker install on G35 sedan with non-bose-image065.jpg
Old Sep 6, 2005 | 12:07 AM
rupdog326's Avatar
The install was pretty much straight forward. The wiring color code for the front speakers are as follows:
Left front speakers - positive is blue and negative is black/white.
Right front speakers - positive is brown and negative is black/red.
I ran the tweeter wires directly to the crossover and the woofer wires directly to the crossover. I then cut off the harness that connected to the old woofer and spliced its wires with new speaker wires and ran it to the input of the crossover.
Stay tuned
Old Sep 6, 2005 | 09:12 AM
rupdog326's Avatar
I will be putting in the new POLK rear coax speakers today. The rear factory speakers are exactly the same as the factory front speakers so the MDF spacers are the same. I thought the rear speakers would be coax.
My impression of the new Polk front component speakers is pure amazement at the refreshing new sound. The sound level at volume 16 is louder than when I had the old speakers set at volume 24. The sound is also crystal clear as opposed to the distorted sound of the old speakers. I also could tell the difference with SCV set at the different levels. I could only imagine the sound when I complete the installation with the rear coaxials.
Old Sep 6, 2005 | 11:42 AM
khsonic03's Avatar
Lookin' good. Only one question though. Did you replace the amp too or the speakers only? I am pretty sure those are 4ohm speakers, it would seem a bit odd that the volume would be louder on those speakers. If our stock speakers were 4ohms and you added 2ohm speakers, that would make sense, but the other way around doesn't. Generally, there is a reduction in volume when switching the speakers on our cars. I am pretty sure even the non bose system is 2ohms.
Old Sep 6, 2005 | 11:44 AM
khsonic03's Avatar
Hmmm....maybe I'm wrong. I just looked at the back of the speaker in one of your pictures, and it *looks* like it might say 4ohm. Check for me if you don't mind.
Old Sep 6, 2005 | 11:53 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by rupdog326
..........As far as I know the speakers on a sedan with Bose can be removed from it's mount and new 6.5" speakers added without modification or spacers.
Bose speakers are the same.
Spacers are req'd for replacements.
Old Sep 6, 2005 | 02:11 PM
rupdog326's Avatar
The first question: I haven't added an amp yet, but it is on the horizon.
Second question: The non-bose speakers are 4 ohms, I believe the speakers in the bose system is 2 ohms.
Old Sep 6, 2005 | 02:13 PM
rupdog326's Avatar
They are indeed 4 ohm speakers. Sorry for the poor quality pics, my digital broke.
Old Sep 6, 2005 | 02:35 PM
khsonic03's Avatar
Ah, ok. That makes more sense then. Haven't dealt much with the non bose, so I wasn't aware that they were indeed 4 ohm.
Old Sep 6, 2005 | 03:15 PM
God|ZIlla168's Avatar
sorry this might be a dumb question but what is the difference between 4 and 2 ohm and generally which is better?
