Alarms With Autostart
Old Oct 2, 2005 | 03:02 PM
Gdup's Avatar
ok so i wanted to upgrade my alarm to one with autostart as well as a 2-way pager. However, my local shop that i deal with has said that there have been some problems with the G35 autostart...something about the tack wire (im just throwing a name out there becuase thats what i remember) anyways he said that the autostart has an issue.....anybody heard of this issue and know how to overcome it?
any help would be appreciated
Thanks
Old Oct 2, 2005 | 03:42 PM
imalazeeass's Avatar
not sure what the tack wire is? but my remote starter worked fine for awhile.. now it works every so often.. maybe it does have problems.. lol
Old Oct 2, 2005 | 04:09 PM
IS300TOG35's Avatar
► Matt ◄
mines been workin correctly since i got it installed. I have a 6spd and it works off the door triggers. Basically when i take the key out my car doesnt shut off. (unless i leave it in gear) It shuts off when i exit and shut the door. If i go back to the car and open it without starting the car then it disables the remote start becuase it doesnt know if somone put the car in gear. So if I leave something in the car and have to get it before i want to leave then i either have to go through the process of starting the car and shutting it off or no remote start for me that night. Other than that remote starts work beautiful on G's and i havent ran into any problems.
Old Oct 2, 2005 | 05:27 PM
el_duderino's Avatar
Usually the tach wire isan issue, not for the car, but for the system trying to "read" it. Different brands have different issues on different cars.
I will check the tach wire on Monday.
Old Oct 3, 2005 | 04:48 PM
Gdup's Avatar
i'm most likely going to be purchasing the compustar unit...would this system pose a problem?
Old Oct 3, 2005 | 05:08 PM
I know nothing directly about Compustars.
I can tell you that Directed recommends the 1-cylinder setting and grabbing the wire at any ignition coil or fuel injector. If the Compustar has a one cylinder setting you should be fine.
g.spot
May 9, 2016 10:54 PM
JMSABO
Aug 4, 2015 11:58 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
1bern
Aug 26, 2003 03:33 PM
