Aftermarket Bluetooth Install Questions
Old Oct 13, 2005 | 09:15 PM
SLVRG35's Avatar
Nope, there is way too much stuff that can be entered for each persons contact info
Old Oct 14, 2005 | 12:10 AM
DDGator's Avatar
Thanks SLVR!
That would be exactly my set up -- same phone and all.
So... can you dial from the car without using the handset or not?
Old Oct 14, 2005 | 01:56 AM
SLVRG35's Avatar
yep, just push the button on the diplay and say the name or # and thats it. works great. it has great range too. I live on the 2nd floor of my apartments and when I remote start my car it connects to my phone in the apartment.
Old Oct 14, 2005 | 11:48 AM
trebien's Avatar
el duderino -
Somebody else kind of asked this - I've been looking at aftermarket BT solutions for my 2005 G35 with Nav to pair with my RAZR. You mentioned that CK3100 that you installed in your car. I've also looked at the Tellphone 4000.
Does it integrate with the stock stereo? Automatically mute the stereo? Play the phone output through the stereo speakers?
I've found a few products that would seem to work, but with our screwed-up Bose stereo system, I wouldn't be surprised if it was all FUBARed. I've installed stereo stuff before, and am handy with splicing and soldering, no problem. Most important is integration with the stero for automatic muting and playing through the speakers. Forget installing some big-*** 5 watt speaker under my dash just for the phone output.
Thanks.
Old Oct 14, 2005 | 01:51 PM
jerdubois's Avatar
I purchased the CK3100 based on lots of recommendations and am getting it installed next week. Will let you know how it goes when done! Got a great deal from cellup.com - $166 including 3 day shipping. Install will be somewhere in the $150 - $200 range depending on where I go.
Old Oct 14, 2005 | 03:45 PM
SLVRG35's Avatar
On mine, TellPhone 4000, I had to also purchase the mute module because there wasn't that option on the bose. With the mute module you use both front speakers in the car. I used the external speaker until I received the module and it wasn't that bad. I put it really high in the pass kick panel area where you couldn't see it.
Attached Thumbnails Aftermarket Bluetooth Install Questions-raytel_radio_mute1.jpg
Old Oct 16, 2005 | 12:45 PM
trebien's Avatar
SLVR -
Does the mute module then automatically mute the radio, or do you still have to push a button to mute? Sounds like it integrates nicely with this module.
Old Oct 16, 2005 | 04:11 PM
SLVRG35's Avatar
it mutes automatically when you receive a call or make one.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nervseele
Jul 17, 2015 11:21 PM
beevanhuynh
Jul 14, 2015 09:06 AM
