Minor Sirius reception issue -- normal?
Old Oct 18, 2005 | 01:12 PM
DDGator's Avatar
Sorry if this has been discussed before, I couldn't find it...
Recently took delivery of a new '05 coupe with Sirius radio. The reception is normally good and I love the variety -- this is my first SAT radio.
I am sure it is normal to lose reception when pulling into a garage, etc. I assume there has to be "line of sight" path between the car and the satellite. However, I notice that occasionally (say, once or maybe twice every 10 miles of highway driving) the reception will be lost briefly -- maybe a second of silence -- then return. This occurs when there are no obvious problems like over-passes, tunnels, tall buildings, heavy tree cover, or the like -- just cruising down open interstate in Florida.
Is this normal? I have had loaner / rental cars with XM and never noticed this happening.
Old Oct 18, 2005 | 01:36 PM
Beowulf's Avatar
That’s odd. I installed my Sirius radio from a dealer kit myself and I've had it for a few months now. It’s extremely rare that it will drop without an obvious obstruction. Before I would assume its problem with your unit I would see how often it occurs on different highways and areas if possible. There might some type of interference on that highway; its also possible that there are an unusual amount of solar flares, but those shouldn’t last much more than 24 hours.
Old Oct 20, 2005 | 09:50 AM
DDGator's Avatar
It has been about two weeks, with regular but unpredicatable drop-outs for half a second to a second. No problems with AM, FM or CD.
Old Oct 20, 2005 | 05:13 PM
Beowulf's Avatar
Hm, how long can you hear the radio when you pull into your garage? It should stay on for 2-3 seconds before it cuts out.
You may need to take it into the dealer; they can swap the sat box in about 10 minutes. YOu may have a bad box.
Old Oct 20, 2005 | 05:18 PM
DDGator's Avatar
From the time the antenna passes under the lip of the garage opening, I might have another second or so of reception. Definitely not three seconds.
Phenomenon9
Aug 9, 2015 01:34 AM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
