Install Nav OK Bypass module--Need Help
Old Nov 7, 2005 | 10:13 PM
SFLG35's Avatar
FGC President
hello
check out
www.kptechnologies.com/forums for all kptechnologies support questions.
we have a lot of info on there about doin the installs
i personally have not installed one so i cant tell you much about it
but kevin as done some installs and can shead more light on it
Old Nov 7, 2005 | 11:14 PM
KPierson's Avatar
You won't need to hook up the reverse input, it is only needed on cars that have an OEM backup camera. To my knowledge the G35 does not have that option.
The Nav board you need is the circuit board that the 'OK' button is physically attached to. You have to remove the radio assembly from the car, take apart the Navi, and then remove the housing that the nav controls are in.
Then you can use a multimeter to to find which solder pad is connected to the OK button (one lead to ground, then probe the pads that form a circle on the board). Push the OK button at each pad and one of them should read 0 ohms to ground when you push the button.
Hope this gives you a jump start, this is by far the most advanced install of any product we sell. Its involved, but not that bad if you take your time, and do it right!
Old Nov 13, 2005 | 10:01 PM
KPierson's Avatar
Great news! Glad you had success.
EnCr1pt3d
Jul 8, 2019 02:48 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Danielek
Sep 20, 2015 12:08 PM
saskicker32
Aug 11, 2015 02:12 PM
