How many grounding points?
Old Nov 10, 2005 | 10:44 AM
waijai's Avatar
i.love.gold
I'll be installing two amps. Should I use a separate grounding point for each amp? Or can I use the same grounding point?
Old Nov 10, 2005 | 10:46 AM
ACEandRueB's Avatar
grounding points
you most definately want to use the same grounding point. Otherwise, you may get a ground loop and accompanying noise. Be sure and grind the paint off of whatever point you choose for your ground.
Old Nov 10, 2005 | 12:47 PM
waijai's Avatar
i.love.gold
Since I'm using 4 gauge for the grounding wire, would it be advisable to use one of these? It fits 1/0 gauge, and I should be able to squeeze (2) 4-gauge wires in there.
Old Nov 10, 2005 | 12:49 PM
el_duderino's Avatar
That's gold and says Stinger on it.
Those are the two reasons I wouldn't use it. But the electrons don't care.
Old Nov 10, 2005 | 04:22 PM
waijai's Avatar
i.love.gold
Is platinum plating better than gold?
Old Nov 10, 2005 | 04:34 PM
afr0puff's Avatar
Supa Dupa Moderator
Both of my amps are grounded to the same bolt in the trunk. Didn't scrape the paint off. I have zero alternator noise or excessive noise.
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
