MY NEW stereo. Pics and description!
Old Nov 16, 2005 | 07:21 PM
ScapGF's Avatar
MY NEW stereo. Pics and description! (not too expensive either!)
So, after asking many many questions on this forum, I finally had my audio system put in place.
Essentially I wanted to maintain the stock look, junk the Bose, add some bass, and get some decent clarity for a decent price. All while maintaining the stock appearance.
Here is all that was done:
1. Replace front 6.5s and tweeters with Diamond Audio 661 components
2. Unhook back and rear deck speakers
3. Install 4channel 600w amp(2 channels for front speakers, 2 for subs)
4. Get custom box to house two Diamond Audio 10in woofers
Since my main concern was sound quality on a budget, I did not opt for some rediculously nice install geared to show off the components of the entire system. I wanted to maintain the functionality and utility of my G35coupe as much as possible.
The 6.5s fit into the stock positions nicely. They had a little trouble mounting the DA tweeters in the stock position, but they made it happen.
The amp was installed on the back of the foldown seats and the box can be easily removed simply by unhooking one wire. This is in case I want to put a full suitcase in the trunk or take the weight of the box out when tracking the car on a roadcourse.
Not sure if you can tell from the pictures or not, but the box is so tightly snug in the trunk that the only way to get it out is to pull with some force. And it is so snug, in fact, that the trunk carpet slides with the box when the box is forced out. Basically they did an incredible job getting the box dimensions to be PERFECT.
Also note that I have enough space to throw in a set of golf clubs!
Anyway, the sound quality is VASTLY improved over the stock Bose system. All of the DA speakers sound fantastic.
Pics below.
Oh, and one more thing. Since I now have no rear speakers other than the subs, would it be advisable to put in some Diamond Audio 6x9s in the rear deck and have them run off of the stock Bose amp(how many watts is this anyway?)?
And if anyone is curious, the entire setup was a little shy of $1200, installed.
Attached Thumbnails MY NEW stereo.  Pics and description!-install1.jpg   MY NEW stereo.  Pics and description!-install2.jpg   MY NEW stereo.  Pics and description!-install3.jpg   MY NEW stereo.  Pics and description!-install4.jpg   MY NEW stereo.  Pics and description!-install5.jpg
Old Nov 16, 2005 | 07:23 PM
MikeyMike's Avatar
Rollin On Dubz
No pics?
Old Nov 16, 2005 | 07:24 PM
ScapGF's Avatar
Originally Posted by MikeyMike
No pics?
They are up now!
Old Nov 16, 2005 | 07:31 PM
my_Gthang's Avatar
congrads on your system...looks good
Old Nov 16, 2005 | 07:32 PM
MikeyMike's Avatar
Rollin On Dubz
I'm sure it sounds awesome, how much does that speaker box weigh?
Old Nov 16, 2005 | 07:35 PM
ScapGF's Avatar
Thanks! The installer was very professional and the work looks great!
Honestly I have no clue! But it is so snug in the trunk that I haven't felt like taking it out and putting it back in yet
Old Nov 16, 2005 | 07:44 PM
kennyq45's Avatar
Where did you get your sub box from and how much? Looks nice!
Old Nov 16, 2005 | 07:47 PM
ScapGF's Avatar
The installer, Auto Restyling Center, Inc., in Ft. Worth, Tx built the box for me at a cost of $180.
I opted for this kind of setup over the 4080 box for a few reasons:
1. With the 4080 box I couldn't quite fit my golfclubs in the back. I took measurements and it was just too close.
2. This box is easily removeable and can be put away if I need the trunk to haul some stuff.
3. This box has just enough space for two 10in subs(2 is better than one, right? ), provided that you opt for subs that don't require much cubic airspace.
Old Nov 16, 2005 | 08:05 PM
silvernole12's Avatar
Where did the installer put the crossovers for the front components? I just bought DA 661s components myself.
Old Nov 16, 2005 | 08:08 PM
ScapGF's Avatar
I didn't ask, but I assume he got it in the door somewhere. Good choice on the 661s, I am extremely pleased with their sound quality
Old Nov 16, 2005 | 10:39 PM
officerp's Avatar
I just got my sedan back today from the installer....DA661s comps in front,D661 Coax in rear doors,took out Bose sub,4080 box with DA M610D4,D3600.1 amp for the sub and D3400.4 for the door speakers. I kept the OEM HU due to money constraints. I had dynamat installed in all 4 doors and the trunk lid. He also used an LC6 to integrate the amps. It sounds fantastic! The difference between this and the bose system is fantastic! I'll try to get pics tomorrow(really not much to see but the trunk anyway!) The DA661s have a incredible sound(at least to me) and seem to put out a lot of midbass too.
Old Nov 16, 2005 | 11:42 PM
ScapGF's Avatar
Cool deal. Quick question though, and this goes for everyone...
I noticed that at max volume(31), the mids and highs are no louder, decible wise, than before the changes were made. Is this normal?
Keep in mind I did ditch the rear speakers and 6x9 speakers.
Should I possibly add some DA 6x9s with bass blockers to help boost the mid/high volume levels? Or is there something else I can do?
Old Nov 16, 2005 | 11:45 PM
Sundeviljay's Avatar
yeah...you can get the double din kit and get a decent head unit....that is the only way that you will get some decent sound...
Old Nov 17, 2005 | 12:07 AM
ScapGF's Avatar
And by 'sound' do you mean 'volume?'
Old Nov 17, 2005 | 07:25 AM
officerp's Avatar
I haven't gone past 25 or 26 yet. I've got a nasty cold so I'm probably not hearing the way I should anyway.I have noticed that the sound really doesn't "come alive" until about 19 or 20. Make sure the speakers in your door have the tightest seal possible to get the best midbass response.
