remote starter with intelligent key?
Old Nov 17, 2005 | 03:46 PM
murzik's Avatar
Is it possible to install OEM remote starter on G35 with intelligent key ? How this works?
Old Nov 17, 2005 | 04:44 PM
Pearl05G's Avatar
An aftermakret remote start can be added on. Theres nothing differently done with the I Key
Old Nov 17, 2005 | 05:38 PM
SagiSRP's Avatar
you'll need to give up your valet key.. as it'll be used to start up the car.. at least when I got my compustar alarm installed that's what they did.
Old Nov 17, 2005 | 11:57 PM
arrivalanche's Avatar
Old Nov 17, 2005 | 11:58 PM
im not sure thats true. with the one we had, the car wouldnt except the key after so long. you would have to unlock the car with the remote again for it to recognize the I-key. I really dont think its going to be as easy as you are thinking.
Old Nov 18, 2005 | 12:08 AM
Pearl05G's Avatar
The I key unlocks the ignition cylinder. Which is not needed for remote start. So actually it is that easy. Not sure why you would have had a problem doing one.
Old Nov 18, 2005 | 12:58 AM
arent you talking about the push button starter?
Old Nov 18, 2005 | 01:25 AM
Pearl05G's Avatar
No Im talking about the Intelligent key with an actual cylinder like asked in the original post.
Old Nov 19, 2005 | 12:53 AM
oic. have you all seen the new push button g35 where you just have to have the remote in your pocket?
Old Nov 19, 2005 | 07:35 AM
Pearl05G's Avatar
On an '07 maybe? Last time I looked '06 was the same as '05
Old Nov 19, 2005 | 10:36 PM
murzik's Avatar
correct me if I am wrong, but if I will leave a key inside a car, dors will be always open?
Old Nov 20, 2005 | 12:27 PM
on the regular one? no. it goes inside a sender that only sends the sinal to the key cyl when activated by the alarm. the key doesnt affect the doors
Old Nov 20, 2005 | 12:57 PM
Pearl05G's Avatar
Whether you have the I key or the standard, your only leaving the valet key in the box which doesnt affect the car itself. It is as posted above only powered up when you activate remote start.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Joe Gargano
Sep 18, 2015 11:17 AM
