Video Ipod *and* Satellite radio at the same time?
Old Nov 21, 2005 | 05:23 PM
kajoob's Avatar
I've done several searches regarding an video ipod and the nav screen, but I can't find any information about having the video ipod *and* satellite radio. I believe the ipod solutions use the satellite input to work and I'm wondering if it's possible to toggle between the video ipod and the satellite radio (or other devices as well, ex. dvd player).
I'm sure it has have been discussed somewhere before but I simply cannot find any info on this specific situation. Anybody know of a thread that discusses this or know if there is a way to pull this off?
Old Nov 21, 2005 | 06:31 PM
amthar's Avatar
From my understanding, getting the TV2NAV mod lets you switch the video output to the stock screen and audio output to the sound system between multiple sources.
Old Nov 21, 2005 | 07:40 PM
G35 1109's Avatar
Talking
Ive done the research...you need the pac unit (PAC AAI-NIS) to connect the ipod where the satellite inputs are. Then there is a separate unit you need to buy from tvandnav2go to connect the ipod video portion to your nav. screen
Old Nov 21, 2005 | 10:40 PM
kajoob's Avatar
many many thanks to you both.
Old Nov 21, 2005 | 11:51 PM
amthar's Avatar
tvandnav2go does not have audio inputs along with video?
and if he has the OEM satellite receiver, the PAC AAI-NIS is not plug and play.
Old Nov 22, 2005 | 12:00 AM
kajoob's Avatar
Do you know the prices for these parts? I don't see prices listed anywhere on either of those sites.
Old Nov 22, 2005 | 01:15 AM
SundipKumar's Avatar
get the pac aai nis
If you want it all, sat radio ipod mp3 playback and ipod video playback get the aai nis. It plugs into the satellite radio port and then you have two sets of rca's. This will allow you to connect your ipod and your external sat radio setup from an aftermarket retailer. Then if you still want video you would need to get a av electronics unit or equivalent to do so. Personally i found the ipod video to be annoying since the downloads take to long. Instead i've just installed a ps2 in my glove compartment and used that for video's instead.
The pac unit is around 80-100 dollars depending where you get it. I have an extra one so feel free to make an offer
The sat radio is whatever you choose it to be
The av electronics units start at 400-500 depending on what you get. I get dealer prices but haven't kept up with the prices so if you decide and want one, let me know, might be able to get you a better price.
Hope this helps.
Old Nov 22, 2005 | 01:30 AM
arrivalanche's Avatar
Tuche`....... The AAI-NIS is on national backorder right now, and, AND AANNDD.... the new unit comming out makes it so you dont even have to have the sat radio option on your radio. I believe it also gives you 2 inputs but dont quote me on that one.
Old Nov 22, 2005 | 03:00 AM
PAC's Avatar
PAC
The radio has to have SAT option. The new AAI-NIS works with or without factory Satellite. The old revision only worked if the vehicle did not have satellite receiver.
Old Nov 22, 2005 | 04:20 AM
symalik's Avatar
so if you have SAT radio in the car, you can still add the PAC unit and have an aux input? interesting i didnt know! so SAT 1 would be radio and SAT 2 would be the aux input? is that how it works
Old Nov 22, 2005 | 09:14 AM
kajoob's Avatar
I have the OEM sirius that plug right into the factory wiring harness. Does the satellite radio have to be aftermarket?
Old Nov 22, 2005 | 09:24 AM
amthar's Avatar
No. Read PAC's post above. The new PAC-AAI-NIS apparently lets you connect your oem sat receiver and add an aux. input as well. My guess is the same as the other poster: Press SAT once for "SAT 1" which gives you your satellite radio (sirius). Press it again for "SAT 2" which will be whatever you choose to connect (ipod, whatever).
Old Nov 22, 2005 | 09:46 AM
kajoob's Avatar
Ahh. Gracias.
Pac - When do the 'new' units that have this functionality come out?
Old Nov 22, 2005 | 12:38 PM
oops. well thats how the girl described it when i called last week. they need to hurry up with these things because im doing quite a few AVelectronics pieces a week in the QX56's and i hate to use a FM mod. luckly most have had the factory video system to save me hastle.
Old Nov 22, 2005 | 12:58 PM
amthar's Avatar
this exists too, although it does not solve the problem at hand I don't think:
http://www.logjamelectronics.com/soundalns1.html
