How the heck does the 06 stereo come out?
Old Nov 24, 2005 | 03:47 PM
jmX's Avatar
jmX
Between the NAV, the dual zone, and the fact that none of the photos show a stereo that looks like what is in my 06, I'm a bit lost as to how to get it out so I can install the PAC adapter behind the head unit. My clock looks like its part of my dual zone screen panel, does all that stuff have to come out?
Ive got the bottom of the stereo/AC/NAV unit all loose, but the top is obviously still bolted down somewhere. I guess I'm on my own ?
Are there shop manuals I can buy for the 06 yet?
Old Nov 24, 2005 | 03:52 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
The HU bracket has one bolt behind the top display.
The diplay is mounted with bayonet clips (really stiff)
Old Nov 24, 2005 | 04:11 PM
AVJunkie's Avatar
I'm guessing that the '06 is the same as the '05 which is different from all previous years. The top bolt holding the aluminum bracket in is directly below the clock. You do not need to remove the clock itself. Remove the trim piece above the clock and then remove the trim piece in front of the clock. You'll then see the bolt that needs to be removed.
Old Nov 25, 2005 | 07:55 AM
jmX's Avatar
jmX
Figured it out guys, thanks for the help!
Old Nov 25, 2005 | 02:22 PM
absolutg's Avatar
workin...
what was the resolution? i have an '06 too and i might have to take things apart to install that PAC unit...
Old Nov 25, 2005 | 08:02 PM
jmX's Avatar
jmX
As suggested above, all I did was tug on the trim around the AC/Clock display up on the dash..the top piece pulls out, and the bottom piece pulls up. After that, there's a big shiny screw right there...no clock or AC panel removal necessary.
There's also 4 screws that hold the stereo bulk to the dash, and you can pretty easily find those by pulling off the trim around the radio.
All in all, its not that bad of a job. Just knowing how the stuff comes off is the challenge.
Danielek
Aug 18, 2025 01:33 AM
Gabe83714
Oct 6, 2015 06:40 AM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
mattdg35
Sep 14, 2015 11:28 AM
2014g35x
Sep 11, 2015 07:53 PM
