Help With Dd Sterio???
Old Dec 2, 2005 | 03:15 AM
futbol333's Avatar
I just received my DD tv/dvd/cd/mp3 lcd receiver and i am about to hook it up. the unit i got only has one plug for the back of the unit so i am wondering, which wires from the G35's many do you take and match up and splice with my new wiring harness. I have done this before but last time the stock wiring harness had lables for everything. Any help would be appreciated. Thanks ahead of time.
-Cameron
Old Dec 2, 2005 | 05:59 AM
jmlaudio's Avatar
if you are keeping the factory stereo except for the source get an OEM interface if you are changing everything else just get a standard wiring harness a metra 7550 in this case you will only need, constant power "yellow" switched power "red" ground "black" and factory amp turn on "blue" also be sure to get an antenna adaptor so you can plug your stock plug into your new deck. Let us know if you have any further questions. Glad to help, good luck.
danzigsdad
Apr 9, 2013 07:55 AM
07_Gcoupe
Dec 26, 2012 11:48 AM
916_G35
Apr 30, 2012 02:47 PM
TOPPER_G35
Jan 26, 2010 01:25 PM
verilath
Jul 9, 2008 09:22 PM
