What do i need to use my stock head unit with an additional amp and 2 12s
Old Dec 4, 2005 | 04:48 PM
BigSash's Avatar
Hey guys, I just got a new G and I want to put in a 800w Kicker amp and my 2 12's.
My question is, do I need some kind of adapter to use these with the stock head unit?
Will they sound good with stock head unit?
Thanks
BigSash's Avatar
Thanks
BTW it's a sedan
Old Dec 4, 2005 | 09:03 PM
SI_G35Coupe's Avatar
i don't think kicker amps have "balanced" RCA input, so you will need a line output converter, aka LOC. it gets spliced into the speaker wires coming from the stock amp (under the trunk floor if you have the Bose) and gives you a set of RCA outputs to run to the amp. you can find the list of wire colors going to the bose amp somewhere on here. that is the easy part.
IMO the hardest part was running the power cable from the battery all the way back to the trunk. not sure how to run it in the sedan as i have a coupe.
as for them sounding "good", that depends. the stock speakers running off the bose amp are lacking in the clarity department as well as bass output. your pair of 12"ers will definitely solve the bass output, but overall it may still lack the clarity in the highs
with 2 12's pushing 800w you will probably have a serious vibration problem. i would recommend dynamatting (or another brand, personally i just ordered a bunch of Damplifier Pro from Second Skin Audio) since my pair of JL 10"s makes my spoiler sound like it's gonna blow right off the trunk if you really crank it.
Old Dec 4, 2005 | 09:52 PM
BigSash's Avatar
Where did you dynamat? just trunk?
Old Dec 5, 2005 | 01:11 AM
nowhere yet... i'm going to do parts of the trunk and the doors first, then in the spring when i have time to take apart the rear seat area i'll do back there
my sound deadener should be delivered tomorrow or tuesday
Old Dec 5, 2005 | 09:08 AM
amthar's Avatar
Not only do you need a LOC, but a LOC that converts differential-balanced inputs to single-ended inputs. Not all LOCs do this. Soundgate makes some that do (I think the LOCPREA is one).
Old Dec 5, 2005 | 03:26 PM
Pearl05G's Avatar
If Bose, a simple splice of a set of RCAs behind the HU or prior to the amp will suffice. The signal being sent is a non amplified, flat. No need for a LOC which converts High level (amplified) to low level.
Old Dec 5, 2005 | 03:41 PM
el_duderino's Avatar
LOCs also convert balanced to single ended. Many amps don't need them, but I bet the Kicker does.
With the Kicker, I'd use a Soundgate LOCPREA myself
Old Dec 5, 2005 | 03:57 PM
BigSash's Avatar
I'm sorry but what exactly is an LOC? and where can I get one/research them further?
Also... anyone know where I can, "find the list of wire colors going to the bose amp somewhere on here."
Thanks again
Old Dec 5, 2005 | 04:00 PM
BigSash's Avatar
K so to answer my own question
LOC = Line Output Converter
I'm guessing the LOCPREA is an LOC pre amp?
thx
Old Dec 5, 2005 | 04:03 PM
BigSash's Avatar
Line Output Converter Part # LOCPREA
The LOCPREA is for you if you've got a factory amplified system and want to eliminate the factory amp. Full DC isolation, full bandwith frequency response, high voltage output, a subsonic filter, and a slight bass boost add up to an awesome way of adding amps to any factory amplified system.
The passive design means it can't be used in systems where AC voltage is very low (some Toyota and Lexus systems, for example).
Do I want to eliminate the factory amp? if so why?
Thanks
Old Dec 7, 2005 | 11:14 PM
the LOC can be used to attach an aftermarket amplifier to the stock sound system, which people would do if they wanted to eliminate the stock amp. in your case, you just want to add on to it, but it works the same way.
Old Dec 7, 2005 | 11:46 PM
Jester4710's Avatar
so how do you add to it? and how did you wire the power in your coupe?
Old Dec 8, 2005 | 02:18 AM
for the coupe, you splice into the output wiring of the Bose amp in the trunk with the LOC... i will post the wiring colors below. i attached mine to the "rear" output wires from the bose which feed the rear 6x9 speakers.
as for running power, it's gotta come from the battery. you can enter the car behind the battery (there is a grommet with all the wiring running to the engine from the ECU behind the glovebox... you punch a small hole in the rubber grommet, run the wire thru, and then make sure to seal it with silicon to keep moisture out). then i ran down along the passenger side of the car to behind the rear seat. below the rear seat in the back there are openings into the trunk on both sides.
Old Dec 8, 2005 | 09:05 PM
Jester4710's Avatar
that sounds like a hassel. i think ill just have someone else install my system.
Tyler's03G
Aug 13, 2015 10:04 AM
kd03g99
Jul 30, 2015 11:24 AM
mjfenix
Jul 14, 2015 10:37 PM
