cigarette lighter question....
Old Dec 21, 2005 | 12:33 AM
Otacon132's Avatar
im drawing 12v/ground from there to a terminal strip to power some mod's and the units for navi conversion.....i was moving it around today to start hiding some fo my mods,a nd i somehow screwed up the power.....im wondering, did i blow a fuse maybe on the lighter? or maybe just loosend some of the wires inside....anyways i need to look into it tomoro in depth - but my main question is, are both cig ligthers in the coupe on the same fuse? or seperate?....the front cig lighter doesnt have power but the rear one does
Old Dec 21, 2005 | 04:51 AM
Meatshackle's Avatar
Deep Sea Moderator
There's a rear cigarette lighter?????
Old Dec 21, 2005 | 09:18 AM
Otacon132's Avatar
in the armrest...
Old Dec 21, 2005 | 09:43 AM
dartmouth01's Avatar
They are on two separate buses, there is one fuse for the acc power, and one for the cig lighter, as listed on the fuse panel. At least thats my understanding, I might be wrong.
Old Dec 21, 2005 | 09:24 PM
Otacon132's Avatar
i found it out - im wrong, front is a cig lighter and rear is a 12v supply, my problem now is gonna be finding a 12v source or a way fo creating 12v to power random mods in the car
Old Dec 21, 2005 | 09:49 PM
Gee Im Fast's Avatar
blue 12 or 15 amp fuse in front passanger left foot well
Old Dec 21, 2005 | 10:10 PM
Otacon132's Avatar
yea, but how safe is it to load multiple loads on each? - and would that be the best way?
Old Dec 22, 2005 | 01:46 AM
You should be fine....usually it doesn't blow because of your load....it blows if your try to connect the power (to the DVD player for example) while the keys are in the ignition at the accessory point or the car is on...that's a no no...always hook everything up (even if it's removable/portable) BEFORE turning the car on or supplying power...
JKL1031
Brakes
19
Aug 30, 2016 08:48 PM
tiguy99
Mar 1, 2016 11:42 AM
willdogs
Dec 8, 2015 11:32 AM
TheBay
Aug 27, 2015 05:08 AM
beevanhuynh
Jul 14, 2015 09:06 AM
