Connections for Nav DVD player?
Old Dec 30, 2005 | 01:56 PM
trebien's Avatar
Anmybody know what connections plug into the back of the NAV DVDROM player in the glovebox? Standard connectors or proprietary?
Thinking of relocating it....
Old Dec 30, 2005 | 01:57 PM
Gee Im Fast's Avatar
proprietary, only way is cutting, extending by soldering in your own extensions. I would not reccomend doing this at all do as it has potential for parasitic capacitances, resistances and inductances...always remember, the shorter, the better for SIGNAL wires....power doesn't care though....
Old Dec 30, 2005 | 02:30 PM
planetstereo's Avatar
I Just Did This Two Days Ago On My Car.i Installed An Avic-d1 With An External Dvd Player.i Didnt Want To Have To Reach Under The Seat To Chage Dvds So I Extended All 25-30 Wires.on The Smalller Wires I Cut A Printer Cable And Cut The Wires One At A Time Til All I Had Left Was The Gps Sensor And The Other Plug.i Also Used A Little Heavier Gauge Wire For The 2 Black Wires And The 2yellow Wires Because They Were A Little Thicker.for The Two Gps Sensor Looking Cables I Used One Sheilded Cable That Had 2 Wires And For The Other Two Pin Cable I Used A Sheilded Wire With Three Wires.if You Have Any Questions Please Respond Back And I Will Try To Answer Them For You.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
vamarris
Sep 26, 2015 12:56 PM
