o5 w/smartkey
Old Jan 5, 2006 | 04:05 PM
killerlexus's Avatar
o5 w/smartkey
is it possible to add alarm to my car if i have smart key?
will i be able to still arm/disarm alarm by pushing button on handle or will i have to hit the unarm/arm button on the alarm remote? i want to add autostart to my car. will that require me to stick my key in to ignition to drive away or will i be able to get in and turn ignition like normal with out key and still be able to drive away? and yes i know i need to leave a spare key in the car to get around imobilizer.i would hate to lose my smartkey functions.
Old Jan 6, 2006 | 12:06 PM
murzik's Avatar
as far as I know you can even add remote start to your existing remote.
Old Jan 6, 2006 | 05:40 PM
finally! a response
Old Jan 7, 2006 | 11:55 AM
Pearl05G's Avatar
Yes you can add an alarm and a remote start, not a problem Ive done a few already.
Although if you continue to use your door button or factory remote it will set the aftermarket alarm off.
No you dont need to put a key in the cylinder to drive away, all will be how it is now.
Old Jan 10, 2006 | 11:49 AM
so i wont have smartkey functions anymore with a viper 791xv?
would i be able to use factory remote to arm and disarm aftermarket alarm?
thanx for your reply
Old Jan 10, 2006 | 01:32 PM
Pearl05G's Avatar
Yes you can, just not to lock/unlock the doors as it will set off the aftermarket one.
If you want to do that, then you would not have a two way and would be limted to range.
Old Jan 10, 2006 | 01:38 PM
amthar's Avatar
I thought two-ways were fo yo peeps to blow you up dawg
Old Jan 10, 2006 | 01:47 PM
Pearl05G's Avatar
LoL
Old Jan 10, 2006 | 10:27 PM
pp7's Avatar
pp7
Let me get this straight. So you can have remote start with intelligent key on an 05 but you wont be able to use the black button on the outside of the door or the remote buttons to unlock it? So the intelligent key is reduced to only being able to start the car without it? Is there any way around this?
Old Jan 11, 2006 | 06:46 AM
so if i just add auto start it would be ok? since no aftermarket alarm.
i would be content with just an autostart, its getting cooOOooold in boston.
Old Jan 11, 2006 | 10:49 AM
Pearl05G's Avatar
If your using any unit that has secutiry (Viper 791 or the like) then it would be pointless to press the button anyway. Thats what the remote is for. But to answer your question, yes that would be true, unless your not using the security features of the alarm, reducing that to being nothing more than just a remote start.
Old Jan 11, 2006 | 10:50 AM
Pearl05G's Avatar
You can add remote start to your factory remote, but as I posted above, youll be limited on range.
Old Jan 11, 2006 | 01:48 PM
pp7's Avatar
pp7
Ah, so as long as I dont use the security features that come with the remote start kit I can still use all the features of intelligent key now? Plus I can get the remote start feature added to my intelligent key so that when i press a certain key combination the car will start? Is it also possible in this situation to be able to use both the intelligent key and the remote that comes with the kit just for starting the car (because the range is longer on the kit or i sometimes might not want to even use the remote from the kit)?
Old Jan 11, 2006 | 02:25 PM
Pearl05G's Avatar
Thats correct.
Old Jan 11, 2006 | 02:42 PM
pp7's Avatar
pp7
Great!! So what kit do you recommend? And is there anything I should tell the installer on how to link it up with the intelligent key?
