Anyone use Audiosource LC6 or 8
Old Jan 24, 2006 | 10:23 PM
Rohas's Avatar
I am setting up a simple audio system with Infinity Kappa's front and rear, a single 10" Alpine Type R, and 2 Hifonics amps running them. I am staying with the stock H/U which brings me to my question. I was thinking about using the LC6 as a line-level converter but don't want to throw away $150 bucks if its more then I need. Has anyone used one of these or have any comments on the product? If it will make the job easier and improve sound quality then I would say it is worth it. If the same job can be done by using a simple $30 converter then it's a bit of a waste. Thanks in advance for the advice.
2004 BS 6MT Coupe
Borla TD, Injen CAI, UR pulley, Pro-1 test pipe, Crawford cast plenum, Megan Coil-Overs, EBC drilled/slotted rotors, Satisfied Gran-sport pads, SPC camber arms and toe bolts, 19' Axis Milanos
Infinity Kappa 6 1/2 components, Kappa 6 1/2 coaxial, Alpine Type R 10" sub, Hifonics Titan TX4405, Hifonics Zeus ZX4000.
Old Jan 25, 2006 | 12:19 PM
netwireless's Avatar
I am surprised there haven't been any replies to this post since I thought a lot of people were installing the LC6 (LC8 is still too new). Car audio magazine for this month has an article on LC8 and recommends it (the article also has a small sidebar on LC6).
I know a lot of people go with lower cost LOCs, but it seems LC6 would be cost competitive if you need 6 LOCs for 6 channels. Any way, found the following post on LOCs in general that also mentioned LC6:
https://g35driver.com/forums/showthr...t=audiocontrol
If anyone has either of these two installed, please post a review. I'm insterested as well.
Old Jan 25, 2006 | 01:44 PM
caelric's Avatar
Actually, most LOC's handle either 2 or 4 channels at once so there is no way you would need six of them; I currently have 2 LOC's in my car, a 4 channel one, and a 2 channel one. I am seriously considering getting the LC8, however, for improved sound quality, and the ability to sum the signals, since I take my line feeds after the Bose amplifier in order to keep the front controls such as fade, bass, left/right, etc... SUmming some of the signals *should* provide better signals to my amps.
We'll see at some future date, since right now I am busy with my carPC install.
Dave
Old Jan 25, 2006 | 04:26 PM
el_duderino's Avatar
There is no reason to use the LC 6 or 8 in Bose cars since the HU has unequalized balanced preamp outputs (in fact, there are many reasons not to).
If you have a non-Bose system with speaker level out of the HU, then the LC6 would make a great deal of sense. I have used them in other cars where I didnot ahve the option to use preamp level signals, and I have gotten them to work fine with some level setting...
Old Jan 25, 2006 | 09:58 PM
Rohas's Avatar
Thanks for the advice, I ended up ordering it after-all since I did read that article in Car Audio praising it. As far as connecting it goes would it be suggested that I go pre-Bose amp or after. I ended up getting the LC6, which if I read the article correctly does not allow channel summing. Even though I did just read that El D said there are many reasons not to use it, and if I saw that a day earlier I most likely would have skipped it, I still hope there are at least a few benefits I will get out of it and I didn't just completely throw away $140. Thanks again for the help
Old Feb 3, 2006 | 01:27 AM
Rohas, did you install the LC6? If so, how is it?
blk35
Apr 9, 2011 10:50 AM
CoolyBwoy
Apr 14, 2010 07:18 PM
Bigrose
Jun 13, 2009 12:43 AM
lancer
Aug 18, 2007 03:09 AM
ARTofAWD
Mar 7, 2005 12:56 PM
