This a bit too much?
Old Jan 31, 2006 | 08:31 AM
Virge's Avatar
straight to the bank...
For my 05 coupe is this amplifier (Kicker KX850.4) any good and if so is it a bit too much for these speakers:
2 channels: Focal 165V1 100w RMS
2 Shared channels:
Focal 690CA1 75w RMS
Diamond Audio D66 1i 100w RMS
The kicker is rated at 175W x 4 @ 4ohm
Or should I just scrap the whole setup....
I was also thinking should I just not bother replacing the coaxials in the back and put in the Focals and get a sub w/4080 and a seperate amp?
Thanks
Old Jan 31, 2006 | 09:31 AM
zcuts11's Avatar
Not real familar with that gear but one option to consider would be:
Use the Kicker amp w/ 2 channels running the Focals (careful to set the gains on the low side as to not overpower them) then bridge the other 2 channels and run a 10" sub in the 4080 W/ that. This set up would give you 175w (alittle less with gains down) and 400+ to the sub. You can then run rear fill (stock speakers or some coax) with the headunit or other small amp.
Convaluted response, sorry, but maybe some ideas.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
vamarris
Sep 26, 2015 12:56 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
