Installed Nano w- ProClip w/ PA11-NAS
Old May 26, 2006 | 07:31 AM
  #121
sonofsnood's Avatar
Originally Posted by Real_G
Do it yourself.. its not very hard. It could be done by a beginner.. just follow the DIY Instructions.
I had to disconnect two plugs ( a small one and a larger one) from the radio(the only two that match the cable) then bigger one that went into the radio goes back into the third FEMALE plug on the cable. I was confused at first becuse when I first looked at the back of the radio there were NO open cavities for the two plugs on the cable, but eventually figured it out.
Its fairly easy.. the hardest part for me was getting to the screw at the top of the radio.
The picture in looking at the back of the HU from the passenger side.
Thanks, the manual says nothing about the small plug so I didn't even use it at first.
Everything is working fine for me now, except I got scratches on my console because I didn't put a towel between pieces of the head unit...
Old May 26, 2006 | 07:55 PM
  #122
blksnake's Avatar
I installed my PA11-NAS today and I am very disappointed with the sound quality with the iPod Video attached. The amount of background noise at low volume levels (<8) is unacceptable.
Anyone else experience the same problem?
Thanks!
Old May 27, 2006 | 05:29 AM
  #123
Real_G's Avatar
An Army of One...
Mine sounds great....<8 is hardley audible. .turn off the "sound check" feature on the Ipod.
Old May 28, 2006 | 01:04 AM
  #124
blksnake's Avatar
I adjusted the amp gain down which helped, but I'm still not totally satisfied. The "noise" sounds like electrical interference with a rhythm or pattern (Not engine whine).
I'll double check my connections tomorrow.
Old May 28, 2006 | 10:02 PM
  #125
sonofsnood's Avatar
Thanks!
I have an Ipod video 60 gb also and the sound is perfect. Like listening to my CD's.
Old May 31, 2006 | 02:29 AM
  #126
cokecan's Avatar
another installed..
With some minor trouble, just got mine done..
Thanks for the instructions and ideas!
-Brian
Attached Thumbnails Installed Nano w- ProClip w/ PA11-NAS-ipodg35.jpg
Old Jun 1, 2006 | 01:49 PM
  #127
flnsx's Avatar
DIY please
Old Jun 2, 2006 | 02:03 PM
  #128
hadman's Avatar
I just installed this on my 03 g35 sedan (not 03.5) and it works perfectly.
Old Jun 7, 2006 | 01:21 PM
  #129
The_Duck's Avatar
I wonder why their site thinks this is not compatible with an 06 G35 sedan w/ non-bose soundsystem.
strange ...
Old Jun 8, 2006 | 11:35 AM
  #130
rabg35's Avatar
Thanks for the info...
Originally Posted by Fuzz
Hello ALL.
I am new to the forum but, have some information that I think everyone would appreciate.
To everyone interested in getting a USA Spec iPod® Interface for your G. Crutchfield sells this item for $119.99. However, let me help you get it w/ shipping for less than $100.
Explanation:
Crutchfield Item #581PA11NIS = $119.99
Promo code ($20 off $100 or more) = 3A172 exp:7/31/06
Call 888-955-6000 to place order, Give item #, Coupon Code, and ask for FREE shipping as a courtesy.
Total:
$119.99 - $20 -$6.99(S&H) = $99.99
I just placed my order and everything went as described. I should have the unit early next week.
I ordered mine Monday.
Old Jun 8, 2006 | 02:25 PM
  #131
gotvenm's Avatar
What does the small plug do ?
My HU recently gave me a "CD ERR F3" so i had to have it replaced. The dealer told me they would hook the usaspec cable up for me when they put the new one back in, but I just got a call saying that its not compatible with my HU. I assume he didnt know what he was doing... He looked online and of course since it doesnt show as compatible with the 03's he gave up.
So it looks like I will be installing this one myself.
Old Jun 10, 2006 | 06:00 AM
  #132
JoeMac's Avatar
I sucessfully install my PA11 today. Took right about an hour. I put my PA11 under the ashtray/radio area and have the cable running into the upper "glove box". Had to drill a 1/2" hole to get it in, but now I have the iPod wrapped in a town in there... out of sight, out of mind. One thing I did notice with the PA11, was that if you only have 4 playlists created, and you select CD 5, it gets stock on that song and you can't change CD's. You can just power cycle and fix it, but still annoying. Other then that... I love it... AND I love just being able to lift out the center console shifter assembly to access the unit for RCA plugs, or dip switch changes.
Thanks for all the helpful pics and knowledge.
God Bless
Joe Mac
03.5 6mt, NON-Bose, w/SAT button.
Old Jun 11, 2006 | 03:18 AM
  #133
buckwildg's Avatar
does this work w/ the 2005 steering wheel?
Old Jun 12, 2006 | 12:27 AM
  #134
sonofsnood's Avatar
word of advice for those with 60gb videos who are getting the Proclip, get the one with adjustable holder, it's a few dollars more but worth it
I have an invisible shield on my ipod and the standard holder is way too tight, so hard to slide in and out, plus it was starting to peel away my shield
the adjustable one is so much better and holds the ipod fine w/o it moving around at all, plus now you have the option of using a skin with your ipod if you like
Old Jun 13, 2006 | 10:10 PM
  #135
rabg35's Avatar
Thumbs up Intalled my PA11-NIS today...
It took me 3 hours from start to finish. I went real slow and cautious so I wouldn't scratch anything. Thanks to all the info supplied by everyone on the this message thread. It helped alot. I installed it where the navigation would normally go. It sounds awesome.
I had one small issue. When I was about to put the stereo back in place I noticed some static coming from the speakers. I checked the PA11 box and noticed that the ipod cable did not fit all the way in. The face plate was blocking the complete insertion of the cable. I enlarged the face plate hole and it inserted perfectly.
