Remote Start: Viper 791XV or 160XV?
Old Feb 16, 2006 | 03:06 PM
Motown_Hog's Avatar
I am purchasing a remote car starter for my 2004 G-Coupe 5-AT. What is the forum's opinion of the Viper 791XV (Security & Remote Start w/2-Way remote) or the 160XV (Remote Start Only)? I found the 791XV for $180 which sounds like a great price. Otherwise I would only get the remote start option with the 160XV.
Will I need additional relays for the door lock/unlock function?
Anything I should have the installer pay special attention to when installing the system? Something about the wiring harness?
Old Feb 16, 2006 | 03:19 PM
spoiled808177's Avatar
Wait for the new Clifford G5 pager alarms should be coming out soon.....will blow the viper away...i currently have the 791XV and waiting for the G5 to come so i can change it out
Old Feb 16, 2006 | 07:01 PM
Motown_Hog's Avatar
Any problems with the Viper? Does it interface well with the stock security system and keyless entry?
Old Feb 16, 2006 | 07:12 PM
nothing is wrong with the viper its great but the clifford is supposed to be the next best thing and blows it away....now fyi if you get remote start for your car you will need to sacarife 1 of your keys....something about some chip in our keys that prevents theft.....and to remote start the key needs to send a signal of some sort to do a remote start. the viper along with the stock alarm is fine you can actually have 2 alarms at the same time....you can still use the key fob normally....good luck
Old Feb 16, 2006 | 10:56 PM
GXCLUSIV's Avatar
Was considering installing the Python 881xp, same is 791xv, but has black lcd remote. Could you state more info on the Clifford G5?
Old Feb 17, 2006 | 10:07 AM
el_duderino's Avatar
Since no one has ever SEEN a G5 av5.5x (including ANY Viper dealer), no one knows if it will blow it away or not. But it will be effing expensive. I would NOT be a guinea pig on this one myself.
Pesonally, I'd get the Clifford Matrix 3.5RSX. Same guts as the Viper, better looking remote.
Remember, overpay for the install. Find the absolute best install shop you can. Most of the cost is install.
Old Feb 18, 2006 | 10:15 PM
pp7's Avatar
pp7
Last thing I heard about the Clifford Avantguard 5.5x was that it wasn't coming out till around september 2006 and would cost around $1500 installed.
Old Feb 22, 2006 | 05:36 AM
Strtsk8r321's Avatar
"Clifford AvantGuard 5.5X
This is simply the most advanced keychain device ever made! Scroll the wheel and see a vast selection of icons (drawn on the LCD screen via Dot Matrix.) Select the icon, enlarge it and press the button to send a command or sensor adjustment to the vehicle via Spread Spectrum, with ultra-extreme range of up to a full mile! That’s just the remote. The system CPU itself is the most advanced Clifford system Directed has ever made, with 3-point immobilization and three separate sensors: digital tilt sensor, OmniSensor and remotely adjustable proximity sensor, with BlackJax anti carjacking, Smart Self-Powered Siren, 3 auxiliary outputs and built-in relays. The AvantGuard 5.5X is simply the state-of-the-art 2-Way vehicle security and convenience system in the world.
This product will be in stock on Wednesday 01 June, 2005."
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
JustinMKN1
Sep 18, 2015 03:40 PM
