Upgrading sound system and keeping stock HU
Old Feb 15, 2011 | 07:54 PM
  #121
_'s Avatar
_
I seem to cant get mine to work properly. Subs sounds weird and doesnt sound how it suppose to sound like. Subs works fine on other car but not this time. Everything seems to be connected correctly. Any mistakes should be pointed out? The LOC was installed by a stereo place called Frequency.
LINE OUTPUT CONVERTOR.
LINE OUTPUT CONVERTOR CONNECTED TO AMP.
Ground, Power REM, +12V(in order)
and btw my friend had this before and he said it was banging normal how subs should of been.
i try mixing up the subs wires and try to get it work. And also tried to mix up the Red and White wire as well and still had no luck
Old Feb 18, 2011 | 02:59 PM
  #122
BazookaJoe's Avatar
Take a look at the link I posted one page back. Your LOC could be tied into the wrong color wires. There is about 20 wires back there so it would have been easy for them to splice into the wrong ones. And they change color depending on what year and trim! Also they should be spliced before the factory amp not after. Maybe your problem lays there. Or just check the basics. Check all fuses and connections. Make sure you amp power light is coming on. Not sure where your REM wire is running off of. If your amp isnt turning on, The Rem wire could be your problem. I ran my REM off of the aux power sig lighter in the front dash.
Old Feb 18, 2011 | 04:15 PM
  #123
Wrathernaut's Avatar
Gentle Manne of Leisure
This has been rehashed in another thread. Your problem is that you're tapping a signal screwed over by the Bose amp, or if your LOC is connected before the amp, it's because you're using a headunit with balanced signals and an amp that can't handle them. The reason it works in other cars is because those headunits output unbalanced signals.
Old Mar 28, 2011 | 03:38 PM
  #124
Tyler285's Avatar
Has anyone put aftermarket speakers and amp with a bose HU and had it sound good? Also has anyone tried this?
http://www.crutchfield.com/p_500PXEH...h=h660&tp=6870
Old Mar 28, 2011 | 08:17 PM
  #125
^ It all depends on the amp, whether or not it takes a differential-balanced signal. If it takes the signal, it'll sound good. If not, it'll sound bad.
That device is for tuning an audio system, not converting the signal, so it won't help at all.
Old May 23, 2011 | 10:10 PM
  #126
dunnkm2's Avatar
2006 G35x My install over at DIYMA:
http://www.diymobileaudio.com/forum/...t-ms-8-jl.html
Old Feb 14, 2012 | 04:54 AM
  #127
BRANDO23's Avatar
Sud
Old Apr 5, 2012 | 01:20 PM
  #128
g35_white's Avatar
i plan to change the stock speakers that came with Bose System. Is it a good idea? I will also be putting a new sub.
What are good options for compos up front and tweeters?
Do i have to make any changes while replacing the speakers?
thank you
Old Apr 6, 2012 | 12:52 AM
  #129
thank you
Did you read the first post?
In summary: If you're looking to upgrade the stock bose sound system, the speakers are the least responsible for the poor audio quality. Replacing the bose amp will go a long, long, long way towards improving the sound quality. So long as that amp is being used, nothing you do will really do anything to upgrade it.
Now, assuming you're going ahead with it anyway:
What is your budget?
What music do you listen to? (This is not a social question. Replying "everything" will get you punched.)
You'll need something to increase the standoff of the speakers from the doors. You can modify the stock ones, but if you consider your time to be worth any money, or don't have much experience in modifying stuff, just pick up some spacers from zenclosures:
http://www.zenclosures.com/Nissan_In...infinitisp.htm
Other than that, it's a pretty easy swap.
Old Apr 9, 2012 | 12:18 PM
  #130
g35_white's Avatar
Well, i didn't read the first post. I just read some stuff about LOC but it all went over my head. So its suggested that one should change the amp. In that case, what's most preferred one?
I listen to Radio most of the time and while i am on CD, i listen to Bollywood (Indian) Songs which focus more on bass which i prefer. Apart from that, i listen to hip hop, R&B, Electronic. I prefer punchy bass. Right now its there, but there is too much rattle from back too. I need to get good dampers too. Please suggest.
thank you
Old Apr 24, 2012 | 11:16 PM
  #131
Hotdawwgman's Avatar
I just want to keep my Head Unit and upgrade my front door speakers with a good component. Ditch the rear and possibly add a small sub in the rear.what should i do?
Old Apr 25, 2012 | 12:54 AM
  #132
paky786's Avatar
Refer back to post #129 (two posts previous to yours). Perfect reply for your question
Old Apr 26, 2012 | 01:42 PM
  #133
I have a non-premium car!
Old Apr 26, 2012 | 01:43 PM
  #134
When it comes to Audio, its like it just flies right over my head! I have no idea what to do, I need a hands on experience to understand how to do it!
Old Apr 26, 2012 | 04:22 PM
  #135
Since you have non-premium, install a line-output converter right under the stock stereo, run RCAs from it to an amp (you could fit a small one under the passenger seat) and then run the amplified signal from the amp back to the speaker wires you spliced into when you ran them to the LOC under the stereo.
So instead of:
Stereo ===== Speakers
it goes
Stereo === LOC === AMP === Speakers
