Key gets stuck in ignition
Whenever I pull the key out of the ignition it gets stuck on the last 1/2 inch of the key. It feels like the bumps at the end of the key are catching onto the inside of the ignition, I have to move the key around to get it unstuck so I can pull it out. Anyone else experience this? Would dealership still fix this under warranty?
The dealership should fix it under warranty.. Sounds like your lock is falling apart. Problems like that tend to only get worse; make sure you get it fixed before your warranty expires.
