Hey Dominic of TVandNAV2Go...
Old Apr 13, 2006 | 11:17 PM
cRai6ory's Avatar
Problem with TVandNAV2Go... Help.
Can you, or ANYone who knows, explain on here exactly how to install (in detail) the TVandNAV2Go unit? With or without pics, doesnt really matter. As long as it's in detail explaining each and every step.
I really dont have the time to call cuz of work and also since youre 2 hours ahead of me. when i do get a chance to call, youve already left for the day.
Old Apr 14, 2006 | 07:39 PM
vsokolov's Avatar
buy 100% plug and play units from www.naviplus.tv no wire cutting OEM connectors
Old Apr 14, 2006 | 08:24 PM
Real_G's Avatar
An Army of One...
https://g35driver.com/forums/audio-video-electronics/90513-diy-tvandnavtogo-pnp-2006-g35-coupe.html
Here is my little DIY I made..
Old Apr 15, 2006 | 03:13 AM
cRai6ory's Avatar
Originally Posted by Real_G
Thanks for the DIY. I had already referenced that while i installed my TVNav2Go Unit. Im sure i made all my connections and grounds secure, but the screen is definitely not how its supposed to look. I have my video ipod connected to the TVnav unit and thats what i use for the video for now. But the thing is, theres lines that scroll down continuously when switched on. Also, i can faintly see the navigation's map behind the video being played. When i have the screen switched back to just the navigation, its perfectly normal. What could be the problem?
Old Apr 15, 2006 | 03:25 AM
cRai6ory's Avatar
forgot to add... my video ipod is connected & charged with the XtremeMac iPod RoadShow .
The Red & White RCA is connected to a PAC AAI-NIS2, and the yellow RCA is connected to the TVNav2Go PnP Unit.
(...if this matters at all)
Old Apr 15, 2006 | 09:20 AM
Real_G's Avatar
An Army of One...
I would cut that lighter adapter and hard wire it so you dont have that big thing exposed.
Old Apr 15, 2006 | 09:21 PM
cRai6ory's Avatar
Hmmm, good idea. Problem is, after i cut the adapter part, i wouldnt know what any of the wires are for and should be connected to. Would you happen to know?
Old Apr 16, 2006 | 10:00 AM
Real_G's Avatar
An Army of One...
Well the positive wire will be the one going straight through to the end of the plug, and the negative will be the one going to the outside of the connector.
Old Apr 16, 2006 | 03:58 PM
cRai6ory's Avatar
thanks for the info. so... i can just connect the positive wire to the car's 12v remote wire right?
Old Apr 16, 2006 | 04:01 PM
Real_G's Avatar
An Army of One...
Yup, connect it to a switched 12v source...very simple and will look 100% better!
Old Apr 16, 2006 | 09:04 PM
SFLG35's Avatar
FGC President
make sure to put a fuse on it though when you hard wire it
Old Apr 16, 2006 | 11:42 PM
cRai6ory's Avatar
i already have my V1 and TVNav2Go both tapped into the cig lighter's 12v remote wire. Would it make a difference if i once again tapped the cig lighter wire? Not too sure if thats bad or not.
are there even any other 12v remote wires i can tap into in that same area? or maybe behind the glove compartment?
i have an '05 with the Bose btw.
Old Apr 17, 2006 | 05:13 AM
cRai6ory's Avatar
F**K. I dont know HOW the hell this happened, but now theres no audio when i play the ipod and it doesnt charge either.
alright so i attempted to hardwire the Roadshow. When i cut the charger part off, inside there were just two separate wires, red and black. Connected the red to a fuse to 12v remote, and black to ground. Tested it.... didnt work. Checked all the connections... they were good. Took the fuse off and tried connecting the red directly to 12v remote... still didnt work.
Then decided to just put everything back the way it was before. I simply just reconnected the red & black wires to the charging part's red & black.
Now the little light on the Roadshow charger comes on, but thats about it. Someone PLEASE HELP. This car stuff is pretty DAMN frustrating... and depressing.
Old Apr 17, 2006 | 06:29 PM
tvandnav2go's Avatar
Cool
Hi Everyone
Our unit is 100% plug and play with OEM connectors and we will beat any price on any RGB unit
Thanks Dominic www.TVandNav2Go.com
Old Apr 17, 2006 | 09:51 PM
Real_G's Avatar
An Army of One...
You figure this out yet? It should have been a simple hookup? Did you try a different ground/power location?
