Wondering Which Optima Yellow Top To Get?
Old May 15, 2006 | 08:35 PM
tekknikal's Avatar
I wanted to create this thread so that if anyone in the future has any questions about this, a simple search will reveal the answer.
Today I installed a 35 series Optima Yellow Top battery in my G coupe. The fit is perfect.
This model is designed for cars with layouts like my 04G, so there is no reverse post 35R model. It also comes with a spacer to raise it a little bit to be at stock height.
There was some debate in some of the threads in the past about which optima battery fits best, and I believe this 35 series is it. The swap is very straightforward and requires no additional work - undo terminal connectors, remove retainer, swap batteries, install retainer, connect terminals and you're done. you do not need to extend any cables or anything. I hope this helps others..
Old May 15, 2006 | 10:51 PM
FortyTwo's Avatar
What are the advantages of the Yellow Top? Versus stock or Red Top.
Thanks for the info.
Old May 15, 2006 | 10:52 PM
khsonic03's Avatar
Um, yeah. I posted this in 2 different threads with pictures. D35. No questions.
Old May 15, 2006 | 11:06 PM
tekknikal's Avatar
red top is better for cold starts under poor (very low temperature) conditions where a lot of current is required off the bat.
yellow top is better for deep cycling the battery (ex: listening to a sound system for periods of time with the car off)
Old May 15, 2006 | 11:09 PM
tekknikal's Avatar
for some reason i remember having doubts. either way i figure 1 extra voice on the matter cant hurt
Old May 15, 2006 | 11:44 PM
SFLG35's Avatar
FGC President
get the d51r
thats what i have and it works great.
it is also 10lbs lighter then stock
Old May 16, 2006 | 07:31 AM
khsonic03's Avatar
The main difference is that the D35 is higher CA's and CCA's for the same price as the D51R.
Old May 16, 2006 | 08:36 AM
rcdash's Avatar
Plus 10 lbs of weight - probably worth it.
The D51R has served me well - fast recharge even when drained down below 11V. Has taken repeated discharges without issues (because of mucking around with carPC).
Freeman186
Sep 6, 2023 10:07 AM
EasySausage
Sep 24, 2015 01:06 PM
yosip1115
Sep 9, 2015 03:30 PM
Feffman
SouthEast
Sep 5, 2015 06:26 AM
