PAC AAI-NIS2 iPod Adapter Installation Guide & 05+ Dash Removal
Old Oct 18, 2011 | 07:54 PM
  #166
Pals4life's Avatar
just to be sure this is what i need for my 2005 g35 sedan with bose
http://www.crutchfield.com/p_581PA15...an.html?tp=120
Old Oct 18, 2011 | 09:30 PM
  #167
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes, that will work, it'll connect to the back of the radio, NOT the plug in the trunk.
Old Oct 19, 2011 | 11:59 PM
  #168
cpezie's Avatar
Originally Posted by cpezie
So I've been looking at adding an iPod connection so I can listen to my music on my iPhone. But can't I just install the PAC AAI-NIS2 and the RCA y cable? I'm thinking that I'd only lose the charging feature but possibly keep the steering wheel controls.
Is that right?
Can anyone confirm my assumption?
Old Nov 18, 2011 | 07:39 PM
  #169
wechslerl's Avatar
Anyone knows how to remove the upper dashboard to install new vinyl?
Are there any screws, how many and where?
Is there any manual or video or pictures?
Old Nov 21, 2011 | 07:12 PM
  #170
Cancruzr's Avatar
I'm adding myself to the long list of satisfied DIYers to the excellent installation instructions and pics here. I have an 06 AT coupe with Nav and Satellite. I don't use the SAT but wanted to run my iPhone through it. I ordered the iSimple PODNISGV6 from iCarKits.com and installed it on the weekend. The manufacturer's installation instructions were totally lame and without these pics I would have had to do a lot of trial and error because of the number of plug-ins. Installation was a breeze: basically plug and play. I love the gateway as I can use the steering wheel controls and it charges my phone. Thanks for once again saving me a ton of coin!
Cancruzr
Old Dec 25, 2011 | 10:31 AM
  #171
cpezie's Avatar
Cancruzr
I just got the ismple setup from icarkits so plan to install today
Old Jan 8, 2012 | 04:22 AM
  #172
xxx4reggie's Avatar
hey guys, question
I have an 07 AT coupe with no navi but it has xm. i listen to it all the time. Which product do I need for it?
I was on ipodcarpros and they have two listed:
http://www.ipodcarpros.com/p203/PA15...duct_info.html
http://www.ipodcarpros.com/p209/PA15...duct_info.html
i'm wondering if both connect behind the radio or does one connect on the xm tuner itself and then I run a line from the trunk to the front of car? Is the XM trunk way better to do? I'm wondering if it's a PITA to run the cable from the rear to the front.
I'd like steering controls and to have my XM working.
Thanks,
Reggie
Old Jan 8, 2012 | 12:09 PM
  #173
Originally Posted by xxx4reggie
hey guys, question
Thanks,
Reggie
PA15-NIS connects at the back of the radio, PA15-INFI connects at the satellite radio connector in the trunk, otherwise they're functionally the same. The INFI will be an easier install, as you won't have to remove the factory radio to do the install.
Old Mar 31, 2012 | 08:45 PM
  #174
MrZor's Avatar
Awesome post!
I followed these steps and did the install on my 2005, It worked perfectly. I only snapped one plastic tab when I was popping off the plastic to the left of the radio. Other than that it went without a hitch!
Thanks again for the post! I don't think I would have taken this on without the easy to follow instructions.
Old May 21, 2012 | 04:41 PM
  #175
dvandriesen's Avatar
Picked up the same setup with the proclip and the type S universal holder just gotta figure out how you screwed that thing to the proclip. Might just used double sided tape.
Old May 25, 2012 | 02:58 AM
  #176
NyCrAzY's Avatar
http://www.ebay.com/itm/INFINITI-FAC...ht_4184wt_1031
Opinions on this for a 2006 G35 Sedan?
& quality is static free, right? As if you're playing a CD or tape player AUX to mp3 player.
Old Nov 29, 2012 | 02:09 PM
  #177
codeyf's Avatar
So much info here, tough to find exact answers to my question(s). First off, '06 sedan. I'd like to be able to connect my iPhone, and be able to listen to Pandora. I would prefer to also be able to charge it without using a separate cable. I would also prefer to maintain control via the iPhone instead of using the radio controls to navigate (they just aren't nearly as intuitive).
Obviously, for ease of installation, I'd prefer to use the rear SAT port. But having to open up the dash isn't a deal breaker for me.
Which unit meets all or the most of my needs?
Thanks!
Old Nov 29, 2012 | 09:16 PM
  #178
Thanks!
The USA-SPEC PA15-INFI, set in direct mode will do what you want. You'll be able to use the steering wheel to skip and control volume.
Old Dec 27, 2012 | 08:29 PM
  #179
herrschaft's Avatar
Started having an issue with the auxiliary cable I have installed on my 2006 coupe (no navigation). Worked with my Ipod for over a year until recently, it still charges the Ipod but the OEM head unit doesn't seem to recognize it anymore. The AUX mode is no longer available. A third party shop recently pulled and reinstalled the transmission so there's a good possibility they fvcked something up since the wire runs under the center console, just wondering if there's something else to consider before removing the interior?
Can't remember which kit is installed but it came from a dealership.
Old Jul 22, 2014 | 01:09 AM
  #180
PLENUMCOUPE's Avatar
So helpful
EnCr1pt3d
Jul 8, 2019 02:48 PM
WillisFL
Dec 29, 2016 08:56 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
