anyone remove stock XM antenna?
Old Sep 18, 2003 | 03:15 AM
jgainsle's Avatar
I got a 6MT fully loaded (seems like unless you order them special that's how they come) with the XM antenna on the roof. Anyone taken it off and moved it? Is it just double stick tape on there or is it screwed on? Where's the xm tuner and where'd you move the antenna?
TIA,
-Jon
2003 G35 Coupe 6MT Black/black
Mountain View, CA
Old Sep 19, 2003 | 02:01 PM
6speedG35sedan's Avatar
Re: anyone remove stock XM antenna?
I had the Infiniti XM installed by Circuit City and I bought the newer version of the XM antenna.It is a little lower profile (smaller) and works even better. Plus the new antenna is magnectic. The one that comes with your car is double sided tape. It will pull right off. It may leave some tape residue, just use some wax to remove the residue. My antenna is on the trunk. I didn't want it on the roof. What ever you do don't put the antenna inside the car (back window ledge). It won't get good reception. Enjoy the XM radio, there is nothing better.
Old Sep 19, 2003 | 03:52 PM
wreck's Avatar
Running for his life!!
as mentioned you can pull it off. As for using wax to remove the tape residue, I don't think wax is going to cut it. After you rub off all you can with your fingers, use Bug and Tar remover to remove the remaining residue.
I have my antenna inside. I satisfied with the reception I get. Only time I drop out is when there is large wide trees above me.
G35C 6MT / AMG E55
Old Sep 21, 2003 | 04:23 PM
G35MD's Avatar
I have a Terk XM3 (low profile) on the trunk. I tried the rear shelf but got bad reception due to my metallic tint. If you have the newer ceramic tint, you should be OK inside the rear window
Dr. Jim
2003 DesertPlatinum G35C 6MT/Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG
2001 Acura MDX/Touring/Nav
1997 Mercedes Benx E320/Eibach Springs+Dampers/OZ Racing Superleggera Wheels
Old Sep 22, 2003 | 12:37 PM
butlermd's Avatar
i placed my antenna on the rear cargo shelf between the speakers and get great reception. very rare brief drop outs in certain locations (1 sec) but my wife gets the same drop outs in those locations and we mounted her antenna on the roof of her Tahoe.
Old Sep 24, 2003 | 07:38 AM
04NismoV35's Avatar
Are the antennas for Sirius the same or do you have to swap them? I just called my dealer to change my order from XM to Sirius.
Old Oct 10, 2003 | 12:37 PM
jgainsle's Avatar
I just took a look at the inside of the car. It looks like if I want to remove the stock xm antenna I need to remove the entire inside roof panel and half the panels in the car to get at the xm wires. Anyone do this? I did a search but didn't find any pics/instructions. Looks like a big job, at least for me who doesn't have the service manual.
Bay Area, CA
Grounding wires - Z intake tube - clear corners
tal1412
Nov 28, 2022 09:25 AM
skippyG
Jan 25, 2016 01:18 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
