Autocross/Road SCCA Solo II Grand-Am Cup, JGTC , Procar SCCA Club Racing, Redline Track Events, Speed Trial, Speed Ventures
Resetting ECU before a race
Old Nov 27, 2010 | 06:02 AM
DivZero's Avatar
Do you do this? If so, what is your method (i.e battery disconnect for 5 mins, 12 hours, something else?)?
How have your results been?
Finally, is anyone aware of a link to an in-depth thread on this topic?
Thanks!
Old Nov 27, 2010 | 10:50 AM
c_morse's Avatar
As always, Search is your friend!
https://g35driver.com/forums/search....rchid=10675868
Old Nov 27, 2010 | 03:09 PM
obender66's Avatar
Originally Posted by c_morse
That was extremely helpful post.
To go to the topic-I do not see any benefit in resetting ECU before the race. Run the engine few times to redline, it will give you 5 whp because it will blow carbon build up out(I've seen it on the dyno)
This is actual link to ecu re-set post. it is useful bit of info to erase error codes whch are not related to real malfunction.
https://g35driver.com/forums/engine-...resetting.html
Old Nov 28, 2010 | 10:50 AM
c_morse's Avatar
You're completely right. There's no use in searching for yourself and looking in threads that have already covered the topic of resetting the ECU. That button really probably shouldn't even be there when you get right down to it, huh?
Old Nov 28, 2010 | 10:55 AM
c_morse's Avatar
And to add something constructive, from the reading I've done in those searched threads, it would seem that the G35's ECU actually learns over time, especially when mods are added to the car.
It's been debated but some think it's better to not reset, while others think it's better to reset after each mod.
I personally reset the ECU after any modification I perform, but I simply don't see the benefit in resetting before a race.
And the true ECU resetting procedures don't come to light until toward the end of the thread that was linked above. Here they are:
https://g35driver.com/forums/engine-...etting-32.html
Old Dec 1, 2010 | 02:25 AM
DivZero's Avatar
I searched.
I'm not interested in HOW to perform the process, but how YOU perform it, and what your results are... specifically in regard to racing.
The idea of a reset before a race would be that the car learns the street style of driving; whereas, I want the ECU geared towards performance. I drive like a grandma on the street--but not at the track. I don't want my first 2-3 runs (out of 4) to be at a reduced torque and lower throttle response. I'm interested in people's opinions who have experience with this in motorsports, hence posting it in this forum.
Old Dec 1, 2010 | 02:51 AM
Deepdiver's Avatar
^ just get Osiris. You can have 5 maps which include the grandma map and race map, all at the toggle of a switch.
Old Dec 1, 2010 | 06:05 PM
obender66's Avatar
Hmmm, now I feel like running a test.
1) Do few 0-60 runs
2) Re-set ECU
3) Do few more 0-60 runs
Oh, no, since you are the OP, why don't you do it and let us know if there was any difference?
Old Dec 1, 2010 | 06:22 PM
Jairen's Avatar
^ The wouldn't be a need. I know for a fact the myth is true. My initail runs at the track are ALWAYS slower even with decent 60ft times. My only conclusion is that the ECU is probably in "grandma mode" since I don't really drive so fast on public roads unless it's a canyon run.
What I usually do is either make a few WOT runs before the track, or if your track is like our here with barely any wait times, knock out a few runs early in the day. I usually do about 3-4 runs (takes about 15 minutes total at our local track to do 3-5 runs), cool off, then start my track day.
Old Dec 1, 2010 | 06:25 PM
thescreensavers's Avatar
Mr.202?
Well for an Automatic, I hear it will shift the fastest it can since it has no idea about your driving style, and I dont think you will get much from the engine.
I have resetted my ECU once, but I did not really look at the times ha, Ill try that next time.
Old Dec 1, 2010 | 07:42 PM
DivZero's Avatar
Good stuff guys.
No Osiris tune for now as I am in stock category. That's a great idea for later.
I'd love to do some non-race testing but have no time for something like that. I'm a full time engineering student, plus I work a lot.
That's great feedback Jairen! Thanks for sharing your experience.
Unfortunately I can't do non-scored laps at the track to switch the ECU out of grandma mode since it's autocross. There is absolutely no fast driving allowed on or near the course before runs begin. I also don't want to go too hard on public roads before the event.
Anyone else have racing Experience with resetting the ECU?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
