DIY: Easy&Cheap LED Side marker mode...:)
Originally Posted by yolkyolkyolk
i might be able to figure this out when i have the parts, but i was wondering how does that white wire connect into the old 194 bulb?
can you post close up shots of the wire connector - the part that connects to the bulb holder attached to the car?
I have circled it in red.
pls correct me if i am wrong. You have a burnt 194 bulb - took out the bulb part and kept the holder. Then connected the white wire (supplied with led strip) to the bulb holder. This holder plugs into the factory wire (which is connected to the car)
Thanks.
Thanks.
i did this mod today and it worked for like two seconds now none of my clearanance lights are turning on. when i put on my clearance lights my turn signals dont turn on either. i think the fuse is blown but i have no clue which is the fuse for those particular lights. can anyone please help me out?
my turn signals work when im turning but they do not turn on with my clearance light.
the clearance strip, side markers, and license plate lights are not working at all
Originally Posted by fsasO6
can you use this with the blinker mod?
ALSO I have 2 of these LED modules for sale. I was going to do this mod, but I'm going a different route... PM me if interested. I have them in "cool white"
