DIY: Fahrenheit to Celsius Conversion
Old Nov 19, 2009 | 04:45 PM
  #31
evolver's Avatar
The idea is right. Here is a shot of my setup. You can magnify the image.
http://picasaweb.google.com/evolvah/...85679839845298
Old Nov 19, 2009 | 05:31 PM
  #32
ResoG35Sedan's Avatar
Alright, will do.......thanks a lot evolver
Old Nov 30, 2009 | 11:53 AM
  #33
Just did this conversion on my 2003 sedan.....very easy and fun to do. I used a switch, so I can easily switch between the two (F and C). Ill post a pic or two, just for fun
DIY: Fahrenheit to Celsius Conversion-g35tempreadout.jpg
DIY: Fahrenheit to Celsius Conversion-g35tempreadout2.jpg
Old Nov 30, 2009 | 12:01 PM
  #34
InTgr8r's Avatar
Staff ALUMNI (retired)
^ nice job with the switch.
Old Nov 30, 2009 | 01:21 PM
  #35
hehe, thanks man
Old Jan 26, 2010 | 02:54 PM
  #36
jtwenger's Avatar
Hi i want to do this mod, but I'm just a little confused about the connecting wire that runs between the two black wires. where do i get that wire from?
Old Jan 26, 2010 | 02:56 PM
  #37
evolver's Avatar
^ Radio Shack, Home Depot, Lowe's?
I used a splicer from Lowe's. See the post #31 in this thread.
Old Jan 26, 2010 | 03:02 PM
  #38
jtwenger's Avatar
OK. i think I might try that, but how do you connect the two wires with that splicer? sorry I've never done anything like this and don't wanna screw it up.
Old Jan 26, 2010 | 03:06 PM
  #39
evolver's Avatar
1. Put the wires through it making sure they are properly aligned.
2. Use pliers to push the aluminum slider into the splicer.
3. Close the clamp.
Done.
Old Jan 26, 2010 | 03:12 PM
  #40
jtwenger's Avatar
OK. so if i use the splicer do i not have to use the soldering iron to connect the two wires?
Old Jan 26, 2010 | 03:14 PM
  #41
evolver's Avatar
Correct.
Old Jan 26, 2010 | 03:18 PM
  #42
jtwenger's Avatar
OK thanks for your help. i think I'll try connecting the wires using the splicer.
Old Jan 26, 2010 | 03:20 PM
  #43
evolver's Avatar
Good luck!
And remember that the trickiest part is putting the clock bezel back in place. I highly recommend what somebody else suggested in this thread--put the two pieces together before inserting them. If you try to do it one by one, they would not align well...
Old Jan 27, 2010 | 07:38 PM
  #44
jtwenger's Avatar
Just wanted to share my success with this mod. it was surprisingly easy as everyone had mentioned especially for someone who has no prior expereince with soldering. i highly recommend this to all my fellow Canadians who imported a G from the states or anyone else who wants Celsius temperature to display!
much thanks to the one who created the DIY and everyone else for their comments and tips.
[IMG][/IMG]
Old Jan 28, 2010 | 01:11 AM
  #45
Shakuya88's Avatar
Just did this today! Wicked easy. Thanks!
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
