DIY: Fahrenheit to Celsius Conversion
Old Feb 25, 2010 | 03:33 PM
  #46
kyokodan's Avatar
thank you phresh ,
just completed the conversion today, very satisfied with the result ,even tho it took me 1hr to do it. thanks for the useful wite up!
Old May 12, 2010 | 09:08 PM
  #47
Jokah79's Avatar
since i've just done it, I took some pictures, hope it can help a little further those who will try it! the post from phresh_5 is very good, very well explained!
this was done on a 2006 G35
2 first pics are for you guys to see the white clips on each part that you have to remove!
then the 2 bolts
i pulled on the module using the 2 plastic parts on the top of the module
you dont need to cut the wires....
get the 2 wires mentionned in phresh_5's post! this is were you should reconnect the module and see if everything works well!
then just tape everything together
and there you go!
I hope this can help a little more!
Old Feb 2, 2011 | 09:43 PM
  #48
brian33185's Avatar
Angry
I was installing a double din and cracked the clock bezel for my 03 coupe. Any suggestions on where I can buy another one or the actual name of the plastic bezel that goes around the clock assembly?
Any input will be greatly appreciated!
Old Feb 3, 2011 | 12:19 PM
  #49
ResoG35Sedan's Avatar
https://g35driver.com/forums/interio...dan-seats.html
Ask, "Heist.".... he is parting out his whole car, I think I saw the bezel on one of his 'for sale' threads.
good luck man
Old Feb 3, 2011 | 12:21 PM
  #50
Here is the thread: https://g35driver.com/forums/accesso...-part-out.html
Old May 29, 2011 | 08:19 PM
  #51
naskomentata's Avatar
Thumbs up video
and short video here
10x
Old Jul 24, 2011 | 04:10 PM
  #52
Speg80's Avatar
Thanks for the great write up, took me a easy 5 mins the most of it was spent trying to figure out the #5 and #36 terminals on the back of the harness... Lol (note, there is 3 black wires on the 06 harness, diagram is viewing the back of the harness) also when removing the lower section of the trim, use a pick in the corner tab holes and lift straight up and becarful when removing the 2 screws not to drop them in the dash
Old Oct 12, 2011 | 02:15 AM
  #53
jeggo's Avatar
I just did this earlier today. Pretty straight forward IMO. (though I broke a clip haha)
I'll just post some pictures too:
[IMG]http://a7.sphotos.ak.fbcdn.net/hphotos-ak-
snc7/307880_2244485784227_1010584691_32047689_144183223 7_n.jpg[/IMG]
Old Oct 12, 2011 | 09:38 AM
  #54
RiCeBrNr's Avatar
Congrats to those who were able to successfully perform this conversion.
Also, thanks to those who followed up and continued to provide further support.
My apologies for not being able to respond, I've been a bit of an entity around here.
Old Mar 12, 2012 | 11:28 AM
  #55
NYT's Avatar
NYT
Just did this on my 07' Coupe. Thanks to all who contributed to this thread!
Bump for other Canadian's with a US car. Now we just have to figure out how to get the spedometer to read KPH as the primary numbers...
Old Jan 15, 2013 | 05:52 PM
  #56
TheIronYuppy's Avatar
Just did it on my '04 Sedan, while also replacing a dead clock bulb. Very easy mod. I was a little freaked when I plugged the harness back an and had no reading at all from the display, but I guess it needs a minute or two to "boot up". Working flawlessly now.
Only took about 20 minutes, and it would have gone completely smoothly if seven years of Florida sun hadn't made the clock bezel so brittle that it broke into ten pieces with the slightest touch.
And of course Infiniti Canada have NONE of those bezels in the country, so it's a three week wait for a new one (and $130!). I think I have some model glue around here somewhere......
oh, and if you're intent on converting your speedo to primary km/h, you can always get some inlay kit. Even a crazy riced-out one with flames or something if you want.
Old Apr 23, 2013 | 12:23 AM
  #57
cu2g8rguy's Avatar
Is there a way to do the opposite? I bought a Canadian 03 G35 that I need to change from Celsius to Fahrenheit.
Old May 5, 2013 | 07:02 PM
  #58
cu2g8rguy's Avatar
Can anyone help me to change the opposite way? I bought an 03 G35 from Canada, degrees are in Celcius and I want to fix it so it reads in Fahrenheit.
Old Mar 26, 2021 | 12:52 PM
  #59
dashkevich's Avatar
g35 AT AWD 05
Hello everyone. Maybe someone came across.
05 restored. Climate! Single-zone! which turned out to be important.
The above instructions do not help, since the wires on the chip differ.
Who collided? Who translated into Celsius?
Old Mar 26, 2021 | 02:34 PM
  #60
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you a non-native english speaker or are you a bot?
You can be honest, I won't judge.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
