DIY : Replacing Low Beam Lightbulbs on 2007 G35 sedan
Old Jul 25, 2007 | 08:21 PM
Pdubz's Avatar
This is more simple than u think..
STEP 1!!!!!
Turn your wheel or REMOVE your wheel (i removed for picture purposes) for more clearance to do this job. then jack it up
STEP 2!!!!!!
Use a flat head screwdriver to remove 4 clips. Then just kinda tug out the fender liner and pull back. shown here:
STEP 3!!!!!
Remove Cap. Use ur fingers and push the two wires together, push forward a little bit, squeeze a little bit, then pull back then u release the hid.
STEP 4!!!!
By now u should know what to do.. if not.. just twist the base of the lightbulb to loosen it and remove.. replace.. and just go backwards.. (securing the wires back is a little tricky but you'll get it with some patience)
I actually did this all by myself w/o instructions.. i stood outside looking at my car and just did it... but its over with.. i'll post a pic of my car with the installed 8000k bulbs when it gets darker..
GOOD LUCK!~!!
Old May 6, 2010 | 08:54 PM
or_G's Avatar
Could I change the ballast this way also?
Old May 7, 2010 | 08:40 PM
03GT35R's Avatar
You should have enough clearance if you take the wheel & liner off to replace the ballast..
Old May 7, 2010 | 10:49 PM
or_G's Avatar
possible to do it without taking wheel off and just turning wheels in?
Jusseth
Sep 13, 2020 12:25 PM
EasySausage
Jul 20, 2015 03:56 PM
