DIY: Ballast Switch for 06 Headlight Upgrade
Old Oct 2, 2008 | 02:47 AM
BokChoiBoi's Avatar
Would I be able to replace the OEM ballast with a 55w ballast? Would a 55w bulb/ballast combo damage anything?
This will be the ballast I will be using from www.retro-solutions.com (great place to get lighting)
Thanks a lot guys
-Yi
Old Jan 26, 2010 | 12:49 AM
willcho415's Avatar
no that is not going to work
Old Jan 26, 2010 | 02:36 PM
PrecisionZ's Avatar
No it won't work and the 55w kits are useless. They do not perform any better than a 35w kit and it will just reduce the life of your bulb.
Old May 6, 2010 | 09:06 PM
or_G's Avatar
how do i access the ballast?
Can I do it from behind the fender or do I need to actually remove the headlight? =/
Old May 6, 2010 | 09:30 PM
or_G's Avatar
why can't I replace the OEM ballast with an aftermarket ballast?
Old May 13, 2010 | 06:02 PM
herolad's Avatar
I'm also in need to replace my ballast and HID, can you access the ballast from the wheel wall or do you need to take the light completely out?
Old Jul 6, 2010 | 01:32 PM
pythonjosh's Avatar
It's the bulb that decides the color/temperature of your light. There's no difference between the stock 35w ballast and that 55w aftermarket ballast, except that your bulbs will not last as long.
And there's a perfect place to put the oem ballast, on the bottom of the headlight housing.
You will still need it to close up that hole even if you go aftermarket.
If you want to change how your headlights look, you only need to change the bulbs.
To change the ballast you can either go thru the wheelwell (easy to access, kind of a pain to change the ballast.
Or you can drop the bumper and remove the headlights. Makes it easier.
Old Sep 6, 2010 | 10:59 AM
gte959s's Avatar
You can replace the ballast by removing the fender wheel well covers. You will need one of those short stumpy screw drivers to get to the third screw on the ballast. Its real easy, no need to completly remove the head light.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
pasjr1972
Sep 1, 2015 10:17 PM
Mick_L
Aug 25, 2015 04:27 PM
