DIY: Replacing Fog Lights
Old May 30, 2009 | 04:02 PM
  #76
turboner's Avatar
i didnt have to jack the car up at all i just turned the wheels to the side and it was very easy to install the lights
Old Jun 9, 2009 | 03:42 PM
  #77
nyckid's Avatar
what if your car is dropped and you have no wheel gap? can you do without removing the 10mm bolts on the underside of the car and just simply let the bumper hang?
Old Jun 9, 2009 | 09:07 PM
  #78
turboner's Avatar
I'm not really sure what you mean. If you're talking about the bolts that hold the plastic piece under the bumper, then I suppose you could go with out removing those but it will be a tight squeeze between the your tire and the bulb housing since you are already dropped. You might to be able to pull it off if you have tiny hands, a good sense of what you are supposed to be feeling for, and PATIENCE !
Good luck
Old Feb 22, 2010 | 05:17 PM
  #79
carumba's Avatar
Great DIY! much appreciated
Old Aug 25, 2010 | 05:40 PM
  #80
lowerd4lyfe's Avatar
Im sure this has already been answered, but what is the best Fog/High Bulb to use, to match the Fatory HIDs. I dont like the stock look, with the Hint of Blue in the HID Low beams and the yellowish color in the fog/high beam bulbs?
Old Jan 31, 2012 | 11:26 AM
  #81
colinhuemmer's Avatar
Thank you for the DIY. I jacked my car up and took the wheels off tho, made it much easier to access everything.
Jusseth
Sep 13, 2020 12:25 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
Freddy07g35
Sep 17, 2015 08:53 PM
attarday
Jul 15, 2015 04:03 PM
You have already rated this thread Rating: Thread Rating: 11 votes, 4.91 average.
