My SPC A-Arm installation
Old Oct 26, 2011 | 11:14 AM
  #181
IAPDirect.com's Avatar
Has anyone installed the shims without getting the abs to act up??
Hello,
Thought I would chime in here. Many folks have installed the shims successfully. The issue was in the beginning:
  1. Installers were not careful when installing the sensor brackets and bent them
  2. The nut provided for the brackets was a locking style which made it difficult not to bend the bracket.
So if the installers are careful when installing the sensor brackets (which now do not have the locking style nut), they shouldn't have any issues.
Hope this helps.
Old Oct 26, 2011 | 06:28 PM
  #182
Frankieg35's Avatar
Yes it does.. i think I'm gonna try to get them installed again and see what happens..
Old Dec 12, 2011 | 12:08 AM
  #183
Frankieg35's Avatar
How many washers did u guys put on the abs bracket?? Spc says 2.. I guess I will do that then go from there if I have any problems..
Old Dec 22, 2012 | 01:00 AM
  #184
ZGagnon's Avatar
6 years later and still a great DIY.
will be tackling this job over the winter
Old Mar 25, 2013 | 12:45 PM
  #185
Electrify904's Avatar
Has anyone had any issues with the revised kit?
Old Jun 15, 2014 | 11:29 AM
  #186
GsxrGirl08's Avatar
SPC rear camber arms
Does anyone know if the SPC rear camber arms will fit over a sway bar. I lowered my car and with the aftermarket ones i have it hits. When i go over a junction in the road the rear end of the car loses control. I'm going to order the SPL rear endlinks but was wondering if the SPC rear camber arms will clear since they are significantly less then the SPL titanium arms.
Thanks!
Old Aug 16, 2014 | 05:00 PM
  #187
Srdatsun's Avatar
The SPC rears fit in very nice I had them in my 04 sedan.
Also wanted to chime on the part when you're taking the OEM arm out remember to take out the little cup that going to seat in side the new A-arm that connects to the arm that goies down to the hub.
One of mines came out easy and the used a pulley puller for the second one.
Be patient. ��
Thanks for taking the time to write the post.
R350k5
Oct 1, 2015 08:41 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
