DIY: Cutting Rear Springmount aka "the springmount mod"
Old Jul 20, 2007 | 02:17 PM
  #31
redlude97's Avatar
Nice, you should be all set. Next up should be a fender roll and spacers for those wheels so they are "hella flush"
Old Jul 20, 2007 | 02:31 PM
  #32
johnjayb's Avatar
damn. for some reason i must live under a rock... why did i not see this thread! lol
  #33
JOKER's Avatar
CLUB MODERATOR
Originally Posted by Kahrupt-CL-S03
Thanks allot for your help, this is great and very easy to do, I didn't even have to remove the strut bolt. Here is my contribution of pics of this mod
What did you do on the front?
Old Jul 20, 2007 | 02:52 PM
  #34
MixturePinoy's Avatar
He's runnin H-techs all around
Old Jul 20, 2007 | 03:08 PM
  #35
Kahrupt-CL-S03's Avatar
Cool!
I have the fender rolling machine, I also have spacers in the front, that's why it looks flush in the front but none in the rear, what spacers do you recommend and how many mm's should I go with? Do they make hubcentric rings that work with thick spacers in the rear?
Old Jul 21, 2007 | 03:13 PM
  #36
JOKER's Avatar
CLUB MODERATOR
Cool!
why cut the "thing" then. Don't it seats low enough with the springs installed?
Old Jul 22, 2007 | 02:46 AM
  #37
redlude97's Avatar
I think we are talking about wheel spacers to make the rear wheels more flush
Old Jul 22, 2007 | 08:48 PM
  #38
JOKER's Avatar
CLUB MODERATOR
^I'm asking him why he cut the rubber thing if he's running H springs all around.
Doesn't it sits low enough with the springs?
Old Jul 22, 2007 | 11:59 PM
  #39
redlude97's Avatar
No, the H-techs are notorious for not lowering the rear much if any at all. See the pics in the thread, they are all of springmount modded h-techs which results in a more even drop, including on my own setup.
Old Oct 21, 2007 | 02:24 PM
  #40
G Thizzle's Avatar
Here are some before and afters. This is how the rear of my car use to stand... i had about a 2 and a half finger gap...
THIS IS HOW MUCH I CUT
BEFORE
AFTER
BEFORE
AFTER
now i have about a 1 finger gap all the way around...I FREAKIN LOVE IT!!! I HIGHLY RECOMMEND THIS MOD TO ANYONE RUNNING Z H-TECHS!!!
Old Oct 21, 2007 | 05:09 PM
  #41
solopresident's Avatar
teamsolo.net im-integline
now not anyone smart, but wouldn't this make the ride harsher? also, how safe is this? I know u said 6 months, but is that really proven milage wise?
Lastly,wouldn't it be safer to get new springs instead of this mod? again, just asking. Im nt smart by any means and also do not own a G35. have the G37, woudl this mod work? My fronts high but rear sits nice.
Old Oct 21, 2007 | 11:19 PM
  #42
AlterZgo's Avatar
solopresident,
First off, this mod will not help you on your G37. This is only to lower the rear of the vehicle. It will not work on the front.
With respect to your other questions, any type of lowering will, in some way, make the ride harsher. Even though the spring rates in the rears are not being changed at all, and the ride will feel pretty much the same, if you go over a large enough bump, the reduced suspension travel would result in the car bottoming out and feeling harsh.
As for whether it's safe, looks like it. You are modifying a non-moving part which the spring firmly presses against. As long as the spring retains enough preload to stay seated at full extension of the suspension, there will be no problems.
Old Oct 22, 2007 | 09:55 AM
  #43
G Thizzle's Avatar
^+1000000
Old Oct 22, 2007 | 05:36 PM
  #44
redlude97's Avatar
Your front wheel gap is alot less than my 350z h-techs, but your front doesn't seem to be that low at all. What is your front tire size? Looks like 245/35/20 or 255/35/20
Old Oct 23, 2007 | 10:51 AM
  #45
G Thizzle's Avatar
^ You are right... it is because i am on 245/35/20 up front... the 20x9.5 compensates for the wheel gap and also raises the car up about a quarter to half an inch...
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
