DIY: Cutting Rear Springmount aka "the springmount mod"
#121
#122
Originally Posted by Boston
It's going to net you an additional 1" - 1.5" inches of drop in the rear depending on how much you cut off. Also if you have an unbalanced drop in the rear with your springs, you can even it out. A very good and cheap mod!
#123
#125
.5" is pretty conservative. I'd take an inch as I don't think that it will give you a negative rake appearance and give you a little more drop. I took as much off as possible but I can also drop my front lower on the coilovers.
#126
I'm pretty low in the back after dialing the Tein's all the way down as well as cutting the top mount all the way down. I've had 2 people in the back and I have no issues. I'm also at a net +8 offset with rolled rear fenders. My rear fender cover the tops of the rear tires while I have a small gap up front. Measurment wise, I'm at an equal height all the way around.
#127
#129
#134
is the creaking coming from the suspension or the roof? I only get one in the roof from the sunroof
