DIY: Installing TPMS on your aftermarket wheels.
Old Feb 19, 2007 | 01:27 AM
accordfreak's Avatar
Use this guide at your own risk. i'm not responsible for anything.
1) buy make a clamp kit.- stock # 4002 http://www.breezeclamps.com/makeaclamp.htm
cut to length
2) buy sheathing clips from home depot (picture 1)
bend it like in picture 1
3)route the band through the clip as show in picture 2
4) put on the tpms by discarding the valve cap and unscrewing the body cap, put the tip through the clip, and screw the body cap back on to secure as shown in picture 3
5) strap the tpms at the dip of the wheels as close as possible towards the center of the wheel on the inside as show in picture 4
optional- you can use double sided tape on the underside of the clamp all around the wheel as a "just in case" insurance.
done
Attached Thumbnails DIY: Installing TPMS on your aftermarket wheels.-img_6139-copy.jpg   DIY: Installing TPMS on your aftermarket wheels.-img_6140-copy.jpg   DIY: Installing TPMS on your aftermarket wheels.-img_6141-copy.jpg   DIY: Installing TPMS on your aftermarket wheels.-untitled-1-copy.jpg
Old Apr 3, 2007 | 04:28 AM
Nickk6's Avatar
How has this held up
Old Apr 3, 2007 | 04:58 PM
thanks. A little over 2000 miles and counting. no problems
Old Apr 3, 2007 | 11:27 PM
Andy2434's Avatar
Nice job, David. I may have to install the TPS units in my wheels. Thanks!
Old Oct 30, 2007 | 03:34 AM
update: over 10,000 miles and no issues..
Old Nov 5, 2007 | 04:14 AM
RealMFG's Avatar
I have an 04 G, would i need to install the TPMS on my aftermarket wheels (when i get them) as well?
Old Nov 9, 2007 | 02:39 PM
citymunky's Avatar
Question
This maybe a NOOB question, but how you can't take off the valve stem from the aftermaket wheels, and install the TPMS in its place?????????
Old Dec 18, 2007 | 07:28 AM
07BlackG35Stud's Avatar
All: 5000+ miles on the exact same kit I purchased from accordfreak and no problems either! Just providing some feedback!
Old Dec 18, 2007 | 02:28 PM
glad everything worked out 07black
Old Jun 14, 2008 | 08:42 AM
ViEtNaStEe's Avatar
So this setup has given you no problems so far?
Old Jun 14, 2008 | 02:23 PM
it's been about 15k and decided to change the tires to a different brand. the tpms' are position like the way the day I put them on. Very solid! no issues! It's not going anywhere!
Old Jun 21, 2008 | 06:35 PM
OCG35's Avatar
Excellent!!! Accordfreak do you have the materials? I think I read that you sell a "kit"... if so, please PM me for 19" rims... if you don’t have - can you tell me where to acquire locally (I don’t have time to order online - install is next week)...
Thanks
Old Jun 21, 2008 | 10:36 PM
jlinc04's Avatar
good DIY, definitely gonna do this on my new wheels
Old Jun 22, 2008 | 04:12 AM
ocg35- sorry i tried to look at the local hardware stores but couldn't find any. you probably have to look at those specialty hardware stores. my extra kit was sold awhile back.
Old Jun 22, 2008 | 04:40 AM
OCG35's Avatar
okay - thanks for the reply... Did you happen to look into a bracket when you decided to band it?... ttrank was telling me about a bracket that is mounted inside - I haven’t seen it, but the way I understood it is mounted on the back side of the stem and TPS attaches to the other side of bracket directed towards the center - inside of tire?...
