DIY: Suspension installed
Old Feb 28, 2008 | 01:00 AM
  #31
SDGeneralCounsel's Avatar
Originally Posted by DieselX
So I finally installed a set of revised shocks and springs from an 05 350z. It was pretty easy and I made a DIY with photos for all you guys. Seriously, don't pay a mechanic to do this, have fun and do it yourself.
http://www.g35nyc.com/forums/showthread.php?t=470
Let me know what you guys think.
used this last weekend. Extremely helpful. Thank you soooooooo much!!!!!!!!
Old Mar 4, 2008 | 09:30 PM
  #32
SlooberTooth's Avatar
I would do this myself but it costs like 200 bucks just for a spring compressor. I dont have a whole suspension, I just have 350z springs so it is a slightly different process, bleh.
Old Mar 4, 2008 | 10:10 PM
  #33
fherjohn's Avatar
you can rent one at autozone/pepboys.
Old Mar 4, 2008 | 10:35 PM
  #34
Never knew that. Do you know the price to rent it?
Old Mar 4, 2008 | 11:01 PM
  #35
fherjohn's Avatar
i dont remember. i think like $20 deposit that you get back. basically free. or you pay 20 and leave a deposit, but u get it back. yeah u can get a bunch of tools. torque wrench also. just go to the autozone counter and they'll tell u.
Old Mar 5, 2008 | 02:23 PM
  #36
Infinite1's Avatar
20 Year Member
You have Tein 350z HTechs or 350z oem springs? Could you clarify?
I'm going to be installing Tein 350z HTechs i hope it's a plug and play affair.
And to the OP....Awesome thread! Thank you! I plan do be using this when i install my springs on my coupe!
Old Mar 5, 2008 | 02:35 PM
  #37
Well the OP posted a DIY for suspension, which is different then installing just the springs.
Old Mar 5, 2008 | 02:47 PM
  #38
Infinite1's Avatar
20 Year Member
Ahh...gotcha!...i was confused for a sec...Seems fairly simple for the rears...the fronts are of concern b/c i'm like you and no spring compressor but i'll check autozone as well.
Old Mar 6, 2008 | 11:38 PM
  #39
MixturePinoy's Avatar
I'm having problems with this bolt. I'm at the point of stripping it. I used a 17mm socket and breaker bar. I even sprayed that PB rust removing lubricant spray.. help!
Attached Thumbnails DIY: Suspension installed-frontsuspension6.jpg
Old Mar 7, 2008 | 12:22 AM
  #40
fherjohn's Avatar
i know u have to wiggle it out. that one is difficult. try tapping it with a rubber mallet.
Old Mar 12, 2008 | 02:49 AM
  #41
Red_G35's Avatar
so when changing the front springs only the shock still has to come out? not quite as easy as the rears, huh?
Old Mar 12, 2008 | 10:05 AM
  #42
Infinite1's Avatar
20 Year Member
Yeah not quite as easy as the rears from what i see as well...I plan on doing this when my springs come in.
Old Mar 12, 2008 | 03:16 PM
  #43
Red_G35's Avatar
my shop said 200 for the install... that sounds better. plus, i dont have air tools and i know some of those bolts are very tight.
Old Mar 25, 2008 | 02:25 AM
  #44
XBrisk202's Avatar
followed this diy this past weekend. Took me a whole day to do the fronts and rears. the DIY is great but pulling out the front suspension is so hard. It's not as easy as the video. I was literally, standing on top of the axle and pushing against the ceiling as hard as I could in order to get it low enough so my friend could slide the oem shock and spring out.
Also, I had spring compressors on the spring as far as possible in order to give me more space to slide it out, i needed every little inch.
Finally, removing the top hat of the suspension was a pain also. I was installing stechs and dspecs. had two spring compressors on and used a breaker bar to get it loose to swap it over to the new set up.
Don't get me wrong, the diy is great, but is it missing something? the video had me baffled into thinking that the diy is missing a step...
p.s. I also used a vice grip and 17 mm wrench to tighten the top hat on my set up.
Old Mar 28, 2008 | 02:48 PM
  #45
Schlad's Avatar
^^^ I take it you didn't you take the endlink bolt out of the front sway bar? I think the suspension would drop further if it wasn't hanging on the sway bar. Sounds like you were pushing against the sway bar.
You have already rated this thread Rating: Thread Rating: 36 votes, 5.00 average.
