DIY: Suspension installed
Oct 23, 2008 | 12:25 AM
  #61
Quote: followed this diy this past weekend. Took me a whole day to do the fronts and rears. the DIY is great but pulling out the front suspension is so hard. It's not as easy as the video. I was literally, standing on top of the axle and pushing against the ceiling as hard as I could in order to get it low enough so my friend could slide the oem shock and spring out.
Also, I had spring compressors on the spring as far as possible in order to give me more space to slide it out, i needed every little inch.
Finally, removing the top hat of the suspension was a pain also. I was installing stechs and dspecs. had two spring compressors on and used a breaker bar to get it loose to swap it over to the new set up.
Don't get me wrong, the diy is great, but is it missing something? the video had me baffled into thinking that the diy is missing a step...
p.s. I also used a vice grip and 17 mm wrench to tighten the top hat on my set up.
I am also baffled how easily you took the strut out. what the hell. It took me all day literally and i still have not finish. I needed to compress the spring almost all the way to get it out of the assembly with very little clearance left. I unbolted the sstrut screw and nut, the endlink nut, and also the A arm screw, pulled down as hard as i can and it had such little clearance still. I manage to get it out and thought the worst has passed but no. Getting it back in was tougher.
Reminder to anyone attempting this. The orientation of the top of the strut where the 3 12mm nuts screw into, it has to be a certain sequence to the bottom of the strut that attaches to the control arm (the bottom of my strut fits the control arm but the 3 screws on the top of the strut did not aligned with the holes. Also the screw you unscrew from the A arm, you have to bolt this back before you attach the strut into the assembly or else it is impossible to put back on.
Going into this DIY i thought the toughest thing would be rusted in bolts and nuts but i was wrong. For those bolts especially the struts and endlink just pb blast it get the ratchet at a good angle, lie down and kick it. It should come free no prob.
Reply 0
Oct 23, 2008 | 02:20 AM
  #62
i had to take out both a-arm base bolts by the top of the strut. it was a puzzle to tighten but it worked! drop is sooooo nice. thanks for the help guys.
Reply 0
Oct 23, 2008 | 10:10 AM
  #63
The trick ( I used) to getting the strut to drop down far enough to snake it out was this: Take an old lug nut, thread it on a few turns, then rotate to the bottom and stand on that beyotch.... bounce if you have to. LOL. I was able to apply a little pressure and use my other hand to snake it out.
Reply 0
Oct 24, 2008 | 12:50 AM
  #64
I've put on the springs and it looks amazing. I use this DIY and it is really helpful. Just a warning though the vid just make the strut looks like it falls out.. It doesnt, You will need some grease some muscles and rice (which by the way taste so much sweeter when doing this ahaha). Also installing everything back sounds easier than it really is.
Reply 0
Dec 12, 2008 | 11:57 AM
  #65
does anyone know if 40 ft lbs of torque too each of the bolts you have to put back is the right amount? I put on sway bars the other day and that's what the manual said to do for them, but i couldnt find one for the springs, thanks.
Reply 0
Jan 11, 2009 | 07:01 PM
  #66
Thanks DieselX! I changed out mine with ZSprings (struts too on front) today. Took about 2 hours thanks to your guide! Oh, and of course my hubby too. He didn't NEED to read it, but I did as I went, just to be sure. Oh, and I dropped a DREADED NUT in the engine bay. LMAO - THEN read....don't drop it. After about 20 mins we got it out.
Great instructions! Thanks again!!
Reply 0
Jan 21, 2009 | 01:31 PM
  #67
i might need the incredible hulk to help me get the bolts out. The 3 under the hood and the bolts holding the bottom of the strut is impossible. I gave up after about 3~4 hours....
Reply 0
Jan 21, 2009 | 02:35 PM
  #68
Soak them with penetrant and let them sit for 24 hrs. Be sure you are using a 6 point socket.
Reply 0
Jan 21, 2009 | 03:06 PM
  #69
That was one of the main things hubby came in handy for. He's a great supervisor too. getting the strut OFF was our dilemma. we had to jack it up a few times until it hit just right. He used his foot to break the bolts on the bottom of the strut.
Reply 0
Jan 21, 2009 | 03:09 PM
  #70
Quote: Thanks DieselX! I changed out mine with ZSprings (struts too on front) today. Took about 2 hours thanks to your guide! Oh, and of course my hubby too. He didn't NEED to read it, but I did as I went, just to be sure. Oh, and I dropped a DREADED NUT in the engine bay. LMAO - THEN read....don't drop it. After about 20 mins we got it out.
A woman working on her own car is sooooooo Sexy!
Reply 0
Jan 21, 2009 | 03:21 PM
  #71
Awww thanks Texas! It's extremely satisfying too, so see how good my drop looks, and I did that! ok, with some help. I have always thought seeing a man working on a car was sexy, so I guess I can see what you mean.
I'm not great, but I'm learning and giving it my best shot. I started small, on my ATV. I can do just about anything on that! Shocked every guy on the trail when I sucked a grass seed into my petcock, so I took it apart, cleaned it and about fell out with the looks on their faces. Priceless.
Looking forward to knowing my G that way.
Reply 0
Jan 21, 2009 | 03:51 PM
  #72
Quote: Shocked every guy on the trail when I sucked a grass seed into my petcock
Oh lawd, I nearly hurt myself...
But srsly, great job, A.
Reply 0
Jan 21, 2009 | 03:53 PM
  #73
Quote: Awww thanks Texas! It's extremely satisfying too, so see how good my drop looks, and I did that! ok, with some help. I have always thought seeing a man working on a car was sexy, so I guess I can see what you mean.
That's what I have been trying to tell the people that want to pay someone to do things like that. Do it yourself! You will feel so much pride of ownership. I look forward to your next project. Try a DIY for the group too!
Reply 0
Jan 21, 2009 | 06:32 PM
  #74
I'm gonna try again on the weekend and i'll be better prepared... I already got PB blaster and I'm gonna go over to my friend's garage and use an impact wrench.
Random question but would installing aftermarket shock/strut lower the car any? I have H&R springs and Tokico HP shocks but I dont want my car to be too low..
Reply 0
Jan 21, 2009 | 09:07 PM
  #75
Shouldn't make any diff.
Reply 0
