DIY: Akebono BBK Installation on 03-07 G/Z
Here is a cheaper option you might want to consider:
http://infiniti.sewellparts.com/acce...2004/4659.html
I just installed them with my Akebono BBK today, and will test them out tomorrow.
I'd never really worked on a car and i had to install spacers so it took me a good 12 hours. I would say do it with a strong friend and a breaker bar or if you had an impact wrench you could probably knock it out in 6 hours for sure. Just lay everything out and a have a good plan of attack.
Easily done in a day. If everything is set up, 4-5 hours. I have an FX so no shields to cut nor brackets to install, but I did the fronts in a little over 1 hour. I used a cheap electric impact gun since getting a breaker bar into the wheel well is troublesome.
Just do the fronts first, then rears. That way if it runs long you can just drive it around until you have time to finish.
Fueled Racing brackets
Hey guys,
Here is a pic of the Fueled Racing brackets I received the other day. These are SWEET !!!
http://www.fueledracing.com
I'm 1 step closer to actually doing the BBK conversion!
Here is the kit---> http://www.z1motorsports.com/350_g35...oducts_id=4626
This is where I got mine http://infiniti.sewellparts.com/acce...2004/4659.html
Awesome ordered brackets last night so this conversion will be started soon. I called in to get prices on rotors and we need them off a 370z or g37s I'm assuming rwd option but it's giving me a L and R at the end of part number to tell me which side. Are they directional rotors when we do this mod?
