DIY: Akebono BBK Installation on 03-07 G/Z
Old Oct 12, 2011 | 07:18 PM
  #61
g-adabout's Avatar
Great write up!
Old Feb 2, 2012 | 11:57 PM
  #62
blAk mAx's Avatar
nice, wondering if my wheels would clear these calipers
Old May 31, 2012 | 09:12 AM
  #63
MN-G-Fever's Avatar
I had my 19" rays on for a short time and I could put multiple fingers between the caliper and wheel. The 18's would clear I'm guessing but not sure about the 17's...
Old Jul 17, 2012 | 09:20 PM
  #64
TunerMax's Avatar
G35
Not sure if Twin is even around anymore, but if so, thanks for this thread!
This is the only thread on this I've found so I might snap some pics while I do it to help complete the DIY. \
Also, purging/bleeding brakes:
Bleed air in the following order. Right rear brake → Left
front brake → Left rear brake → Right front brake
1. Connect a transparent vinyl tube to bleed valve.
2. Fully depress brake pedal several times.
3. With brake pedal depressed, open bleed valve to release air.
4. Close bleed valve.
5. Release brake pedal slowly.
6. Repeat steps 2, through 5, until clear brake fluid comes out
of bleed valve.
Old Jul 29, 2012 | 08:14 PM
  #65
linedr89's Avatar
very purrdy
Old Aug 12, 2012 | 05:50 PM
  #66
TunerMax's Avatar
G35
Install pics
As mentioned earlier thought I'd try and help with a couple more pics, but I have to re-upload the pertinent install pics.
For now just some sexci installed pics that already uploaded
Old Feb 13, 2013 | 10:46 PM
  #67
WILLIE BEANS's Avatar
Originally Posted by jutn35
I just want the front Calipers/Rotors on my G but i have the 17 Stock Chrome Wheels. Will they fit inside?
does anyone have a definite answer to this question .?
im planning on ordering the akebonos for my 03 sedan and i still have the stock 17"
rims in the picture quoted .
i need a definite answer asap ..
please
anyone?
Old Feb 14, 2013 | 09:46 AM
  #68
soundmike's Avatar
18's are the smallest you can fit over the Akebono's. The inner barrel on 17s won't clear even if you have a wheel with great spoke clearance.
Old Feb 14, 2013 | 10:26 AM
  #69
TunerMax's Avatar
G35
I had a large crash and lost a lot of pics, but forgot to update this thread with the few I held onto. Not much help for install I don't think, but here we go:
Before:
After:
Rear Before:
Rear After:
Random install pics:
Old Feb 16, 2013 | 08:24 AM
  #70
Michaelh90's Avatar
Great thread. Got my akebonos install pretty easy. Before i start my installation i was trying to find out if they would fit over my sport g35 wheels and i couldnt find anything bout it. So i just try them and the fronts fit very tight. U have no space between the calipers and barrel barely 1mm. Here are some pics for anyone looking for pics in the future. By the way i went over a pothole and bend the wheel i started to hear a knockle sound i figure out the wheel was heating the caliper had to put my donur..
edit: i was using 25mm spacer.. with out the spacers in the front they wont fit.
Old Apr 6, 2013 | 05:03 AM
  #71
TORETTO's Avatar
I wonder if these would clear my 18" work equips...
Old Apr 6, 2013 | 09:45 AM
  #72
TunerMax's Avatar
G35
Very doubtful
Old Apr 6, 2013 | 04:32 PM
  #73
TORETTO's Avatar
Barrel clearance or spoke clearance?
Old Apr 6, 2013 | 04:56 PM
  #74
TunerMax's Avatar
G35
probably spoke on the equips. All the offset is in the lip, not the center, if that makes sense. So the spokes are actually really close to the hub/centerline.
Then again, there's really only one way to find out. Find someone with Akebonos and try it. Unless you want to do that silly 'Measuring' thing that people talk about (people, pfffft)
I could be completely wrong too, the equips aren't aweful for barrel, as long as the spokes have enough offset it might work.
Are you running spacers? That would help your chances.
I do know that the G37S 19" spokes are actually within a few mm's on the front, not a ton of room there, and those spokes are out quite a bit. When the 19's were on stock brakes I could stuff a rabbit in there and still be good.
Old Apr 6, 2013 | 08:53 PM
  #75
TORETTO's Avatar
i'm counting on my disk size, you got a number i can text you pics at? pm me or something bic boi
