NEED HELP 911, "slip warning light"
Old Sep 18, 2009 | 10:29 AM
manh3's Avatar
I have a 04 2drs / Auto and having a situation with my vehicle. Whenever I go off an off ramp curve my "slip light" will go on and will cause the whole car to lose control. It seem like its coming from the front. Other than that my car is fine. So far I have reset my ECU and have checked my brake fluid and for leak but everything is fine. Can anyone help me out? Please pm me.
Thanks in Advance
Old Sep 18, 2009 | 03:33 PM
Krispyklene's Avatar
do you think perhaps your tires are in bad shape? and perhaps not staggered?
Old Mar 12, 2010 | 10:08 AM
MJP_24's Avatar
its ur vdc. the car does that when it feels its about to lose control. therez no problem with it. just make sure u check ur alignment and ur control arms.
Old Mar 12, 2010 | 10:18 AM
GreenGoblin's Avatar
The goblin resurrection
stop trying to take the off ramp to fast and the vdc will not try to save you.
Old Apr 1, 2010 | 04:02 AM
Pk_g35's Avatar
I had the same thing this morning the slip and vdc turned on for no reason, took some time to turn of by turning car off fully and back on, wonder if this is just a persisting isue for everyone or just some traction isues for a few ppl
Old Apr 1, 2010 | 03:09 PM
Chris'sG's Avatar
i have the same problem when going off an off ramp in my 04 a/t g35 coupe.
If i turn off the vdc and try it again will i just start to whip the back?
Old Apr 1, 2010 | 03:23 PM
nghiars's Avatar
The slip and vdc light is likely turning on due to lost of traction. Whether its from hard cornering or worn tires, you should validate this and take the appropiate measures to correct it.
Old Apr 1, 2010 | 03:25 PM
nghiars's Avatar
Have you checked your brake fluid? You may be low and when you cornered hard, the fluid moved. That's probably why you needed to turn off your car and let the fluid settle down in order for there to eenough fluid in the brake lines.
Old Apr 1, 2010 | 03:32 PM
Pk_g35's Avatar
well ill check that but what happen was I grove out this morning and was driving normally I came close to a stop but rolled past it and the slip,vdc and break light were on but the hand break wasnt on. I went to gas station to fill up so car was off for like 5 min but after I turned it back on the lights were still lit, it was only after a few more miles that I totally turned off the car at red light that it turned off.....would this be break fluid or something else?
Old Apr 2, 2010 | 02:48 PM
mabaty's Avatar
No SES light though? Sounds like brake fluid is low to me, if your "BRAKE" light is on.
mabaty's Avatar
The BRAKE light will come on if fluid is low, not just when E-Brake is on.
Old Apr 2, 2010 | 04:36 PM
Pk_g35's Avatar
well how do you explain the vdc coming on? not like i was burning out and turned on it just turns on and stay on...but yea ill fill fluid this weekend
Old Apr 2, 2010 | 09:29 PM
mabaty's Avatar
Well VDC is Basically just braking; therefore brake having issues = VDC issues. I'm not saying that is what it is, just trying to help you troubleshoot. Did you check fluid level??
Old Apr 2, 2010 | 11:54 PM
Pk_g35's Avatar
havent checked yet cuz Ive been working all day but tomorrow morning ill spend all day checking out car stuff and detailing....ill let you know if it
solves it so others can do the same
Old Apr 4, 2010 | 09:55 PM
Pk_g35's Avatar
ok so I checked fluids and all are normal level....it was funny i turned vdc off and startedburning out a bit and slip didnt turn on so i kept driving until i reached a stop, as soon as i stopped vdc slip and break turned on. Anyone have an idea whats the problem??
