Crazy Lights After Stillen Sways
Old Jun 27, 2006 | 08:13 AM
fijbert's Avatar
so I installed my Sway bars,
and I've been getting this problem ever since:
and sometimes my Brake light comes on for no apparent reason...
Old Jun 27, 2006 | 08:56 AM
wnt1bd's Avatar
Sways should have nothing to do with that.......
Old Jun 27, 2006 | 10:09 AM
Bigd2k6's Avatar
looks like a trojan virus.
Old Jun 27, 2006 | 10:14 AM
gspotter's Avatar
Looks like the TPS is on. Does one of your tires have a slow leak?
Old Jun 27, 2006 | 10:30 AM
pdjafari's Avatar
my eyes, MY EYES!!!!
Old Jun 27, 2006 | 10:41 AM
w0ady's Avatar
fgc moderator
you probably bumped a sensor when installing your sways. i believe its the vdc or something like that, try doing a search on here.
Old Jun 27, 2006 | 01:58 PM
fijbert's Avatar
dealership installed my sways..
I'll check them out
Old Jun 27, 2006 | 02:34 PM
kenchan's Avatar
it needs a refill of some sort.
Old Jun 27, 2006 | 02:49 PM
G35 Mass's Avatar
Plug in your wheel speed sensors
Refill brake fluid. (If its not to the max fill limit, the lights will come on. Some have experienced this symptom with the fluid halfway between the max and min limits)
Old Jun 27, 2006 | 03:00 PM
escobar929's Avatar
i can see three light coming on from your pic: tps, vdc and slip
what setting are you running on the sways. you may have too much oversteer and its causing the slip light to come on
check your tire pressure, or do you have aftermarket rims?
Old Jun 27, 2006 | 04:32 PM
skc's Avatar
skc
i hate that fvcking light!
Old Jun 27, 2006 | 06:16 PM
SKRich78's Avatar
LOL...i hope i dont come across those problems when i get sways
Old Jun 28, 2006 | 11:42 AM
Scootch's Avatar
dam..hmmm
Old Jun 29, 2006 | 08:36 PM
fijbert's Avatar
my tire pressure is low (got that fixed)
I was driving in a straight line
and the sways are on the hardest setting
Old Jun 29, 2006 | 09:05 PM
jameyb's Avatar
Hmm, never seen that before. If the dealer installed them, just take it back and make 'em fix it.
Put your seatbelt on and one light will go off.
