What lowers the Coupe more Tein S-Tech or Eibach Pro?
Old Jul 12, 2006 | 11:29 AM
OZSponsoredjti's Avatar
Im tooo lazy to search after surfing here all day....... I know that they state how low the drop, but its once the springs settle thats important. Which is lower when all said and done??
Old Jul 12, 2006 | 12:39 PM
boxa87's Avatar
ummmm im not sure which one lowers it more but if you want i have a pair of h-techs for sale that i never used (desided to wait until i can do the whole suspension) for 120$
Old Jul 12, 2006 | 12:49 PM
Basheer's Avatar
Call the Cops
the eibach sportlines drop it more
Old Jul 12, 2006 | 12:56 PM
Kyosho's Avatar
Eibachs are lower. From what I've seen the rear sags just a little bit more.
Old Jul 12, 2006 | 07:03 PM
w0ady's Avatar
fgc moderator
um he asked about eibach pro. the s-techs will be lower than the pros.
Old Jul 12, 2006 | 11:25 PM
Basheer's Avatar
Call the Cops
oh oops
Old Jul 12, 2006 | 11:41 PM
silver g's Avatar
I do not know if you have aftermarket wheels, but just FYI, if you care about tire wear the Eibach Pro Kit drops your vehicle enough to require front and rear camber kits and a rear toe kit to get the tires to wear properly. If you have aftermarket rims chances are you are running 275 tires or larger in the rear which are expensive to replace. I can only imagine the situation would be worse with the S-Techs since the drop is more dramatic. But if you do not care about tire wear then go with the S-Techs. There is nothing sicker looking than a slammed g.
Old Jul 13, 2006 | 02:47 AM
truplay8's Avatar
THE BATMOBILE
tein
Old Jul 13, 2006 | 02:09 PM
kenchan's Avatar
Prokits will lower more than the S-Techs for the coupe.
Old Jul 13, 2006 | 06:28 PM
dR6's Avatar
dR6
Are there any springs out there that will lower about an inch and NOT require a camber kit?
Old Jul 13, 2006 | 08:14 PM
w0ady's Avatar
fgc moderator
350z h-techs lower about .8" front and .6" rear. sometimes they settle a tad lower.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
andresito7
Aug 1, 2015 04:53 AM
lemmy999
Jul 25, 2015 12:13 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Kal Hamm
Jul 24, 2015 08:55 AM
