when to change brake pads(brembos)
Jul 14, 2006 | 08:48 AM
I have just turned 55K and had 4 new Michelins installed at NTB and inspected the pads myself... It looks like there is at least 30% left so I will order some pads and rotors soon, but I am in no rush to change them, they really look pretty good for all the miles.
04.5 6MT, TB\Graphite Prem pack, aero kit... At 55K, running better than ever!
Reply 0
Jul 14, 2006 | 10:33 AM
I heard squeaking often at low speeds, and I checked the pads when I was changing the rims, and the pads had about 50% of the meat still left. The rears had little less than the fronts. Looks like I'll be changing the rears before my fronts. I need to check up on them again, as few months have already passed.
Reply 0
Jul 14, 2006 | 12:34 PM
On mine ('03 6MT) the inner rear pads wore down the quickest. There have been several other folks on this board who reported the same thing. Note that there are no squeel indicators on the inner pads, only on the outer pads.
I changed my rear pads at somewhere around 35K. Fronts still good (at about 37K now).
Practical advice - at 30k it makes sense to pull the wheels (or have someone else pull the wheels) to check wear on both inner and outer pads, front and back.
Reply 0
Jul 14, 2006 | 04:27 PM
Quote: On mine ('03 6MT) the inner rear pads wore down the quickest. There have been several other folks on this board who reported the same thing. Note that there are no squeel indicators on the inner pads, only on the outer pads.
Yeah, I check em every 6-10K miles when I change the rear tires... I have em pull the fronts and balance then check everything when wheels are off... NTB lets you back in the shop area with no complaints.
Reply 0
Aug 1, 2006 | 02:06 AM
This is my cherry popping post, yeah me. Anyway, changed the front brembos '04 at 28k rears have 30% left. Left rear has ALWAYS squeaked. Only left rear. Saw a girl driving an auto coupe once and hers did the same. Has this been talked about??? Doing searches now.
Reply 0
Aug 1, 2006 | 02:09 AM
Quote: I have 22,000 miles on my 03 and before I went autocrossing, I pulled the wheels to check the pad thickness. I have over 50% left in the front. I did not check the rears.
you should watch the rears, the inside pads in the rears seem to wear a heck of a lot faster than any of the others..
Reply 0
Aug 4, 2006 | 03:41 AM
Quote: I have 30k and j/w when i need to change my brembos brake pads...
Mileage can only give you an idea or concern to check your brake lining life. Shops cannot recommend new pads by just mileage, you will have to measure your pad lining.
rule of thumb, if you look at your pad lining and see that the thickness is about the thickness of a coin, its pretty much time to change. best thing to do is measure with a ruler and check for minimum spec.
Reply 0
Aug 4, 2006 | 08:06 AM
At 44K, have about half the pads left...
Reply 0
