GTSpec Aluminum Mid Chassis Reenforcement Brace for G35 Coupe
Old Aug 19, 2006 | 03:19 AM
  #31
timzcat's Avatar
This thread is rediculous now. It is quite obvious what the braces do if you ever bothered to look under the car.
The suspension braces in the rear especially are suring up the mounting points which are an aluminum open-box design. I could easily deflect these areas with a pry bar and about 50 ft. lbs. of force.
The X-brace requires no explanation if you've even put a unibody car on a lift or even jacked one side up.
Old Aug 19, 2006 | 07:01 PM
  #32
cato's Avatar
SouthernComfort Moderator
I was speaking with Ken at GTSPEC the other day about the failed 4-point chassis brace install on my G35 sedan. He said the brace does inseed fit the G35 coupe. They made the sedan different from the 350Z, but not the G35 coupe.
Old Aug 21, 2006 | 01:49 AM
  #33
timzcat's Avatar
Thanks for the information cato.
Old Aug 21, 2006 | 04:51 AM
  #34
636Racer's Avatar
you could probably mark, drill, and tap new locations to mount the gtspec brace on a sedan. I know there's more to it that just that as far as reinforcing the mounting points. but it's not impossible...it's just what extents you want to take to make it possible.
Old Aug 21, 2006 | 08:09 AM
  #35
cato's Avatar
Yeah, but if it dosn't fit my sedan, I don't want it. No reverse engineering here...
Old Sep 13, 2006 | 07:26 PM
  #36
MechEE's Avatar
Hahaha... you can always count on SixFive IQ to wage a logicless imaginary argument against comments of his own design. The lack of reading comprehension is scary really.
As I originally stated, I'm still interested to hear people's experiences with these bars. Clearly adding bars to various locations can have effects ranging from absolutely nothing to huge improvements in structural rigidity, and there's more to it than just finding a pair of nuts between which you can fit a bar under the car. But in SixFive IQ's world, you can't even talk about the possible structural rididity benefits of adding a TypeR badge to the back of your car without actually having one on your car.
Old Sep 15, 2006 | 03:36 PM
  #37
MechEE's Avatar
Originally Posted by SixFive
Go back to myspace and argue with the teens TROLL
What's wrong, can't find where I ever suggested that these bars were a joke and didn't work?
You should start making it a habit to actually read and comprehend posts before you start your flame wars.
Old Sep 15, 2006 | 03:45 PM
  #38
MechEE's Avatar
Originally Posted by badco
I'd buy it if it would make my G stop creaking like an '82 Camaro with T-Tops when I back out of my driveway.
Do these things work, or what?
Personally I'd be very surprised if the effects of adding the upper rear bar were noticeable. If you look closely, the bar mounts in parallel with a much larger parallel aluminum cross beam structure integrated in to the body. The added stiffness of this little bar relying on a friction bolted joint for coupling would seem negligible.
Old Sep 15, 2006 | 09:07 PM
  #39
obender66's Avatar
It is probably the case when complicated teminology("finite element analysis") will not work.Did anybody tried to apply "finite element analysis" to backscratcher? I bet no, but it still works.
Rule of the thumb is -the stiffer the better. Look at WRC teams who re-weld all car seams. "They are already welded", you may ask, "what's the point?"
So the more stiff stuff, (hard liquor and wood in your pants included), we have in the car the better.
I convinced myself about usefulness of STB long time ago-took one off so I could clean throttle body in one of my old cars and went for a drive. Car felt very flimsy and unstable. I never felt that before I installed STB and was always happy with the handling....
I don't have GT Spec bars yet, but I am definetely getting them.
Be simple, man.
Sure, I may have designed and constructed stiffness-optimized vehicle frames and suspension components with finite element analysis and analyzed changes in stress and strain distribution in detail for research during my work with a vehicle dynamics research group, but hey, I don't actually have the bar on my car, so my comments mean nothing in comparison to the "dood, I can totally feel the difference!"
Old Sep 16, 2006 | 12:01 AM
  #40
MechEE's Avatar
Be simple, man.
Sure, you can say the more stiff the better, but what price are you willing to pay per % increase in stiffness? $1/%? $1000/%? $100000000/%? The problem with the "I can feel it before and after" tests is that you're aware of what you're looking for, and you'll find it... you need to have many blind before / after trials where you don't know when the bar is installed or not, and you label which feels better.
Again, I am not claiming that they don't work, only that it's not obvious that they do. What would be nice is some average before and after track times that showed consistent improvement.
Old Sep 16, 2006 | 09:59 AM
  #41
obender66's Avatar
$150-200 seems to be very reasonable for GT spec bars.
Rewelding entire chassis would be just stupid
Old Sep 16, 2006 | 05:18 PM
  #42
MechEE's Avatar
Reasonable based on what? The cost of manufacturing? Sure. The $ per stiffness increase? That's indeterminate.
Old Sep 17, 2006 | 06:14 AM
  #43
markiev37's Avatar
Anybody know how much the mid chassis brace weighs?????......And I know Tanabe has a mid chassis brace also but I believe I read that it hangs a little lower than the GT spec mid chassis...thanks
Old Sep 17, 2006 | 05:50 PM
  #44
obender66's Avatar
No, it seems reasonable as per member's reviews. Everybody who installed them noticed improvement in handling and reduction in interior creaks.
Old Sep 17, 2006 | 07:37 PM
  #45
MechEE's Avatar
Sounds promising. Anybody who tracks their car have a set of these that could do some time trials with the only change being the bar?
