Staggered sizing, 20" rear 19" front
Old Aug 19, 2006 | 10:43 AM
k_hojnacki's Avatar
1st, yes I used search but little to no information. Is anyone running a staggered wheel sizing 20" rear and 19" front similar to the MB? I'm curious on how this affects the overall balance of the car. Thanks
Old Aug 23, 2006 | 03:38 AM
shyrock's Avatar
It's perfectly fine as long as you stay within the same overall diameter of wheel/tire combo to keep your VDC light from engaging all the time
Here's a link to a 19/20 staggered setup:
https://g35driver.com/forums/wheels-tires/103982-dpe-gt7-staggered.html
Old Aug 23, 2006 | 05:25 PM
DHCrocks's Avatar
as shyrock stated the key is keep the original diameter. The ideal setup would be 255/35/19 and 285/30/20, that's just about dead on stock diameter. It actually works out that staggering the front/rear 19/20 can get you closer to stock diameters then all 19s or all 20s. The only problem and this is a big one, is that only a few brands make tires in those sizes so your selection is limited.
As far as balance, it's fine. I haven't run into any quarks or bad traits in this setup. If anything it seems like there's a little less understeer. since the diameters are the same VDC is not affected and I haven't run into any issues here.
vitamin.v
Nov 7, 2019 06:10 PM
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
