Anyone have any exp with iRotor stuff?
Old Aug 24, 2006 | 10:49 PM
RIG35Guy's Avatar
As in the rotors? Had a buddy who was a big Subaru tuner and swore by iRotor rotors and pads.
Old Aug 25, 2006 | 12:22 PM
RIG35Guy's Avatar
Bueller? Buller? :-)
Old Aug 25, 2006 | 01:44 PM
Q45tech's Avatar
The only way you can tell the quality of a cast iron rotor is to do a metallurical analysis to determine the [if] expensive additives added to the iron.
A decent simple test is to compare the weight of aftermarket to oem, if the vane count and end surfaces are the same thickness [~~9mm] the heaviest one is denser.
Difficult because 80% of world rotors are made in China and may be branded and rebranded and rebranded [box labeled] along the way.
We can buy a $22 or a $53 or a $91 or a $109 front non drilled or slotted rotor for a Q45 unless you measure and weight and examine accurate you wouldn't know which units are which! Especially which is the better value.
Time/miles to warp vs retruing or change labor.
Old Aug 25, 2006 | 02:54 PM
RIG35Guy's Avatar
eee
Old Aug 25, 2006 | 02:55 PM
RIG35Guy's Avatar
LOL! So outside of a metallurical analysis and actually buying the rotors to compare to OEM...
No one has ever tried these?
Old Aug 27, 2006 | 01:39 PM
BuckeyeG's Avatar
My brother has a set on his maxima and loves them.
Learned Hand
Oct 1, 2015 09:02 AM
Detailed Image
Sep 22, 2015 02:26 PM
Detailed Image
Sep 17, 2015 07:38 AM
Detailed Image
Sep 11, 2015 08:37 AM
Detailed Image
Sep 8, 2015 02:42 PM
