SPC front camber delivery extended!!
Old Aug 30, 2006 | 11:40 AM
chester's Avatar
hey def tell us how it performs.. hope this product is a success..
Old Sep 3, 2006 | 06:53 AM
chester's Avatar
any updates?
Old Sep 3, 2006 | 09:38 AM
kenchan's Avatar
i don't see why you guys would even need those... im running -1.8
and it's fine (great cornering response, tires wearing flat). actually,
even if i had stock ride height i would dial in about -1.7 to -2 up front.
thats why most camber kits are agressive in the negative side and
barely any adjustment for positive.
i say screw those arms and just get your money back. get something
else.
Old Sep 3, 2006 | 09:43 AM
Chico's Avatar
else.
I have to agree. Part of the reason why I wanted them was to obviously correct the camber a bit to bring the top of the wheels closer to the fender. Otherwise I wouldn't do it as I love the stance and feel of my car at -1.5 camber. On the other hand I can go with more agressive offsets in the front on my next set of wheels.
Old Sep 3, 2006 | 10:13 AM
Gsedan35's Avatar
else.
I dunno, their a a number of people that are either running drops just for looks or have gotten themselves into setups that are going to be hard on the insides of the front tires if they push their car's very hard. Though you and I are in the same camp Ken, I'll take all the free negitive camber I can get, especially in the front.
Old Sep 3, 2006 | 10:51 AM
Andy2434's Avatar
Great! The Suspension gurus have all spoken. Geez . . . Now, you guys have given me something to reconsider. My front camber is at -1.3 left and -1.9 right and I am loving the way the car handles. If the additional tire wear is not going to be that much more, I would seriously consider dropping my order. I have some 4000 miles on my front 255/35x19 set-up and without raising the front end up, I can't see anymore tire wear on the inside of the treads . . . And there has been 100's upon 100's of miles of hard driven twisties on this set-up.
Thanks for chiming in guys. You give me food for thought.
Old Sep 3, 2006 | 12:19 PM
chester's Avatar
You guys do make a point, my only concern is buying tires after tires for my 20" gt-c which isn't cheap, and you can feel the car isn't in good shape when the tires are worn out in the inside which kinda wobbles. I also heard that the drive is much better and smoother when people got their front camber back to specs and that i could feel a difference in a good way! I don't track my car, just cruise and get on it at times! Ill think about this.
Old Sep 3, 2006 | 02:47 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
r u guys serious?
none of you see more tire wear on the inside than the outside? i've been lowered for 23,000 miles or so and there is definitely more wear on the inside.
i don't have my camber numbers with me, but am lowered on Eibach pro-kit.
if you're happy with tires that last 25,000 miles, than you prolly don't need this camber kit. I have Toyo T1R tires.
Old Sep 3, 2006 | 03:09 PM
chester's Avatar
mine gets worn out on the inside a lot n the ride gets crappy.. how are the t1r compare to the t1s with your eibach, I am also sitting on eibachs.
Old Sep 3, 2006 | 03:17 PM
Hexxum001's Avatar
I'm definitely installing a rear camber kit on my G to try to bring it as close to spec as possible. As a matter of fact my camber kit is already at Status waiting for me. But I have talked to a few people that say the same thing as above. As long as you are within half a degree or so of spec, you really don't need a front camber kit. After I get my rear kit installed, I'm gonna get an alignment to see where I am at and take it from there.
Old Sep 3, 2006 | 04:00 PM
chester's Avatar
i wonder what my specs are right now if i am lowered on eibachs..
Old Sep 3, 2006 | 07:32 PM
aleok's Avatar
now i don't know if i should wait to order them or preorder. or just get some kinetex a-arms. but i know i'm going to need a lot of positive camber. planning on dropping 2.5-3 in.
Old Sep 3, 2006 | 08:50 PM
Hexxum001's Avatar
Wow. I wouldn't recommend that bro. I am lowered on Tanabe DF210's and I scrape all of he time. Some speed bumps are also a hazard. The DF210's only lower your ride 1 1/4 in the front and 1 3/4 in the back and it may be too much.
Old Sep 3, 2006 | 09:11 PM
aleok's Avatar
yea, right now i'm lowered to 350z s-tech, which is about the same height as you. but feel its not low enough. i would really like to be tucking tire. or just close the gap all together.
do you guys think i should wait, however long, for the SPC front a-arms or just get kinetex, now?
Old Sep 3, 2006 | 09:21 PM
  #30
ryanwiggum's Avatar
My car is lowered on tein s-tech (on the verge of switching to eibach prokit), each sides camber is at -1.8. I've had Toyo T1Rs since January of this year. Yesterday I had my tires cross rotated and the front tires aren't really that bad. They aren't exactly wearing flat like kenchan's but it isn't that bad. The rears, on the other hand, that's a different story (camber is measured at -1.4 for both sides in the rear).
I placed an order a couple of weeks ago for the a-arms not only to correct the front camber but to bring the top of the wheels closer to the fender. I don't really like the tucked in look.
If you dropped your car about an inch you shouldn't really worry about your front tires wearing out. Pay attention to the rear tires.
