350z H-Tech_Bump Stop
Old Sep 26, 2006 | 04:35 PM
Tweaksalot's Avatar
id like pics of both! cause i have the h-techs. . . and i dont think the drop in the rear is good enough. To me it still sits really high.
Old Sep 26, 2006 | 05:01 PM
borahatch's Avatar
Here are the pics of the piece I cut:
Top view
This is what it looked like installed on the spring. Of course, this is the half inch that I cut off... the leftover spring mount has a cone shape and goes down in between the spring coils.
Old Sep 26, 2006 | 06:01 PM
borahatch's Avatar
And now a few shots of my car:
I'm thinking about getting spacers for the rear wheels to push them out a little more (like the front wheels). What do you guys think?
Old Sep 26, 2006 | 06:57 PM
Sooner97's Avatar
I agree, the car would look much nicer if the rear wheels were more in line with the rear fenders.
johnbigbootie's Avatar
it looks to me like a fair amount (maybe too much?) neg camber, if you adjusted that out a bit the top of your rear wheels would "push out" closer to the top of your fender? Maybe an alternative to spacers...
Either way your drop looks sweeeet! I can't wait to drop mine!
Old Sep 26, 2006 | 07:04 PM
borahatch's Avatar
LOL, at your sig johnbigbootie! Thanks for the compliments. I'll see what I can do about the rear when I get the car aligned.
Old Sep 27, 2006 | 01:01 PM
redlude97's Avatar
borahatch,
what did you use to cut the rubber spring mount?
Old Sep 27, 2006 | 06:07 PM
borahatch's Avatar
I used a hack saw. I used a large C clamp and a piece of wood and had my friend stand on the wood to hold the rubber steady (should have taken a pic of this so you could see what I mean). Then I just cut away. It'll take about 3-5 minutes to get through the rubber.
borahatch,
Old Sep 27, 2006 | 07:00 PM
Tweaksalot's Avatar
wow. . . .i need to do that right now. . . your rear sits so much lower compared to mine
Old Sep 28, 2006 | 02:28 PM
Fox233's Avatar
So i must say the drop looks great in the rear now, however I have a small concern as to what detremental effects cutting that piece out can have on the ride and/or suspension. I mean it had to be there for a reason right?
Old Sep 28, 2006 | 02:33 PM
borahatch's Avatar
The car rides the same as stock, no noticeable difference there. I'm pretty sure there wont be any negative results from the piece I cut off (except a tad more neg. camber). See, I only cut a half inch off a larger body of rubber. So that piece is still on the car, just not as tall .
Old Sep 28, 2006 | 06:40 PM
redlude97's Avatar
Any way you can draw a quick schematic? I can't really picture how the wood and c-clamp were set up and I'll need to do the same thing with mine likely
Old Sep 29, 2006 | 04:07 AM
borahatch's Avatar
LOL, you asked for it!
So basically, I don't have photo shop (wouldn't help if I did, suck at it.) So I did the best I could with MS Paint. This pic pretty much sums up what I did. Install the c clamp as pictured, have your friend stand on the wood so the rubber doesn't move, and saw away. I hope this basic drawing helps somewhat. Feel free to laugh at my Paint skills
Old Sep 30, 2006 | 04:47 AM
Tweaksalot's Avatar
next question. . . how much can i pay you to do this for me
Old Sep 30, 2006 | 04:12 PM
  #30
borahatch's Avatar
LOL, we could work something out.
