aaaayyyy, holy &$%#^
Old Oct 19, 2003 | 04:00 PM
tig488's Avatar
for those who did their springs, how in the &^$% do you take the top part off to slide the spring off, i got the entire assembly of but i cant get the large nut off, when i turn it the shaft turns too, its about to drive me apeshit. anybody have any suggestions.
2003 G35 Silver/Graphite 6MT Prem Cp
19" Gunmetal TE37s 275/30 Michelin Pilot Sports
kg/mm supersport springs
custom camber rods
injen CAI
Alpine/JL Audio/Stinger
double din, he-he-he
Old Oct 19, 2003 | 04:37 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Re: aaaayyyy, holy &$%#^
Gotta Use A Spring Compressor..... Either Go Rent one or Take it to A Custom Shop and Pay them to switch them over.....
I'm Just A Simple Man, Trying to Make My Way Through The Universe......."JangoFett"
NismoCPV-35
Old Oct 19, 2003 | 04:51 PM
tig488's Avatar
i got a spring compressor, the spring is fully compressed, im talking about the main bolt in the center of the shaft on top. nothing to do with the spring.
custom camber rods
injen CAI
Old Oct 19, 2003 | 05:18 PM
zimbo's Avatar
You're not alone!!
I've done springs for two different G35s now (I totalled the first one two weeks ago) and I haven't been able to get that nut off w/o using an impact (i.e. air) wrench even when the spring was pulled down clear of the rubber at the end of the strut.
The first time, I took the strut assembly (with compressor clamps still affixed to the spring!!) to a mechanic and asked how much he'd charge to remove the nut (he did it for free--took him about 3 seconds). The second time I borrowed a friend's impact wrench and air compressor. Only took me about 1 hour to do both front struts!
In the absence of that, I would recommend using a breaker bar and hitting it with a hammer. You'll need a small wrench to hold the bolt while you whack away at the nut, however. Otherwise the whole thing will turn as you pointed out.
--Steve
Old Oct 19, 2003 | 06:04 PM
wreck's Avatar
Running for his life!!
What zimbo said.
You need an imact wrench. Just take your struts to a gas station and they will remove it for you for free. When you put the them back on, drive there and have them tighten them up for you.
G35C 6MT / AMG E55
Old Oct 19, 2003 | 10:01 PM
tig488's Avatar
i finally got it guys, thanks for the tips, i ended up turning the whole assembly upside down and sticking the tip in a vise then sliding a open end wrench in and loosening the nut, was actually easy once i thought about doing it that way. i have an impact wrench but that didnt work they both still turned. the first side took about 3 hrs, the second only took 1.
custom camber rods
injen CAI
paranormal
Jun 20, 2005 04:05 PM
lookin2buy35x
Jun 18, 2005 07:34 AM
mcml3693
Mar 5, 2005 10:39 PM
